First Post, 350 TPI question
Old Sep 17, 2007 | 07:32 PM
87350formula's Avatar
I recently purchased an 87 350 TPI formula with the "performance suspension". I did a quick search for info regarding performance mods and I found one post that linked several articles most of which were no longer any good. My question: is there a good comprehensive source for tuning and modifying 350 TPI cars? I know that such literature exists for Ford EECIV systems and I'm hoping that a good source exists for TPIs. My goal is one HP per cube on the 350 engine while maintaing excellent street manners and creature comforts. I feel this is a very attainable goal. Are there any sources/companys that provide parts lists to work toward this goal? I haven't searched yet but I assume there is a good source on this site for RPO codes. I want to figure out what suspension I actually have. Thanks!! Yes, my other car is a Ford Maverick with a fuel injected 340 horse 5.0 liter crate motor!
Old Sep 17, 2007 | 08:16 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: First Post, 350 TPI question
you have WS6 suspension all Formulas and GTAs had this as standard equipment. It's the best factory suspension on Firebirds--and some would say, Camaros (which did not have WS6)
With a good intake, heads and cam 350 is doable.
http://www.moates.net
My car is runing Tuner Pro R/T from them
Old Sep 19, 2007 | 09:21 PM
thanks for the link, another simple question, would the 87 350 formula have the 5.7 HO decal on the hood power bulge? finally, I would think better exhaust would be part of the equation above, true?
Old Sep 20, 2007 | 06:37 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
The best learning site I've found for learning to tune TPI is close. Go over to DIY Prom section and go through the tutorial about a hundred times. It'll pay off ten fold.
Ron
Old Sep 20, 2007 | 07:30 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
My 89 350TPI had the power bulge hood and didn't come with a 5.7L decal. I do know that you can get a 5.7L decal on the web though.
Headers and a free-flowing exhaust would be essential to that equation. After all, what good are upgraded intake, heads, and cam if they can't breathe well?
Hope this helps!
Old Sep 22, 2007 | 12:16 AM
thanks for the replies
Old Sep 22, 2007 | 12:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hell, an HSR and full exhaust will get you near 300hp on the motor... a simple cam swap will get you 350 hp and drive just fine. port the heads isnt necessary but a mild clean up is worth 15-20 hp...anyone can do it...it seriously is just a mild port clean up with a grinder to gain 10 cfm or so and 20 or so on the exhaust side.
cheap LT4 hotcam and intake upgrades will get you close to 350hp on motor or near 315 at the wheels
for tuning look into moates.net for their chip adapter, burn1 programer and aldl cable for datalogging... read up on MAF tuning in the DIY adn you'll be set to do a 350 hp reliable daily driver motor
Old Sep 22, 2007 | 01:40 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Still all that chip burning junk and make the move to OBD II. The link is on the top of this forum.
Old Feb 10, 2008 | 11:37 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am bringing this one back.
87350formula: If you were asking about books, here are two that I have and found very usefull:
1) How to Tune & Modify Chevrolet TPI Engines by Jason Scott
2) How to Tune & Modify Chevrolet Fuel Injection by Ben Watson
However, this thirdgen.org board is your best source for advice and understanding how TPI cars work. Dont give up on this site, even if you did not initially get as many responses as you were hoping for. There's about a dozen guys here who could write their own books.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
