Plug wires for Slp header installation
Old Mar 9, 2001 | 06:14 PM
Killer-Z's Avatar
I've got a 91-z 305 tpi. I'm getting slp headers and was wondering if you guys would tell me what plug wires to get. Whose are the best?? Forget cash i just wanna get the best. Thanks-Derrick
Old Mar 9, 2001 | 06:21 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You want the best, you can have the best!!! Taylor just came out with ceramic boots on a spriral wire. I think they are in the ballpark of 188.00 for a set.
Realistically, MSD, Moroso, and for a good bang for the buck check out Summit racings 'spiral' universal sets. They last! and are $31. Get spirals and whatever brand you get, DONT GET ACCELL!!!
You need 90 degrees on all boots.
Old Mar 9, 2001 | 07:34 PM
black5.7GTA's Avatar
Livewires www.performancedistributors.com
1990 Trans Am GTA,Black/Black leather,350 auto 3.23,SLP package,SLP torque converter/shiftkit,GSC's,G-tech 0-60 5.1 1/4mile 13.6@104
Previous Thirdgen
1986 Camaro IROC-Z
Old Mar 9, 2001 | 09:46 PM
1BADAZTA's Avatar
Why not Accell wires? Is there something wrong with them? I have them on mine and I haven't had a problem. Maybe you know something that I don't. Please explain.
88'TA 305TPI 330HP, NATURALLY ASPIRATED, PASSES N.J. EMMISIONS. "I AM JUST THAT GOOD"
Old Mar 9, 2001 | 10:13 PM
GTAMAN63's Avatar
Taylor wires are nice, you can get a standard spiro core set for about $50. You will need to assemble them yourself though. Don't forget to get a good wire harness. Made for You makes a nice center bolt valvecover loom set. Keep those wires from touching the headers, they will last much longer.
Barry Izold
89 T/A, GTA
Modded 350/T-5
Old Mar 10, 2001 | 07:35 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Doesn't matter what wires you get, if they stay on the header long enough they will melt. The key is the wirelooms. I got "Just for You" wire looms for center bolt valve covers and with my Taylor wires I've had no problems melting wires on my 1 5/8 SLP headers. If you need a pic I can e-mail you one. Very neat looking installation.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 10, 2001 | 10:26 AM
88TAGTA's Avatar
I've used Taylor 10 mm spiral Pro Wires and fiberglass Firesleeving. Works very well.
Old Mar 10, 2001 | 02:24 PM
Killer-Z's Avatar
DO I have to get a universal set or can I get a set of custom made wires for a thirdgen camaro? I need 90 degree angle boots.
Old Mar 10, 2001 | 04:49 PM
GTAMAN63's Avatar
I wouldn't chance it. Most custom fit sets are made for the stock exhaust manifolds. (Mix and match of boot ends) If you see a custom fit set with all 90 degree boot ends, it should fit. Still, I would recommend making them yourself. All you need is a plug crimper, ($15) the universal sets come with everything else. If you run the wires through wire seperators (like the center bolt dividers) and cut them to length, you can't beat the look. Less chance of them burning on your headers too!!
Barry Izold
89 T/A, GTA
Modded 350/T-5
Old Mar 10, 2001 | 08:45 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
If you go with factory wires you will need to get them for an 90-95? about those years 95 for sure gmc or chevy 350 pick up they use the same cap as we do and all of the wires should be 90 deg. boots
Old Mar 12, 2001 | 12:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
88 is correct, get ones made for a 93-95 Chevy truck, 350 TBI. They're 8mm instead of 7mm, and they fit perfectly on a 87-92 Thirdgen.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 12, 2001 | 11:24 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Any of the top brands are good. The secrect is to keep the plug wires off the headers.
I have the SLP headers and a TPI. I bought plug wires which have 90 degree boots at the spark plug and where extra length. I installed the wires on the plugs and ran them up through "just made for you" wire looms on top of the centerbolt valve covers. Then I cut the plug wires to proper length and installed the metal ends at the distributor. No more burnt plug wires!
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Mar 12, 2001 | 05:22 PM
Killer-Z's Avatar
Do you feel that the factory wires are as good as the aftermarket? Does anyone have any expierience w/this? Thanks again.
Old Mar 13, 2001 | 09:45 AM
Hank Brote's Avatar
Not all aftermarket wires are better than stock delco wires. My preference is with Jacob's.....
Hank
87'IROC Z28
Hanks 87 IROC
Old Mar 13, 2001 | 06:38 PM
JoelOl75's Avatar
I had packard wires on my car for 6 years. I figured I'd change them so I put accell on and after a year (not even) i developed a miss. After testing the wires (ohms) one wire had a radically high impedance, so I changed JUST THAT ONE with an old packard I took off (I don't throw anything out, but thats another story) and less than a month later another one bellied up developing a miss. They were not burned (6 cyl with manifolds and the factory heat sleeves were in place) and the ends weren't the prob. Bending the wires changed the resistance from 15,000 ohms to 80,000 to infinity ohms. I now put all the old packards back on and now they are on there for another 3 years on top of their previous 6! They work fine. Now I wouldn't recommend them for an extreme heat 'header' or CD type ignition, but it shows exatly what I think of Accell wires. I wouldn't put them on a lawnmower. I wouldn't use them to tie garbage bags shut.
My brother used similar wires 'accell extreme 9000' and ended up paying a better buck for these. And more since a bad wire caused his module to bite the dust. OK maybe one module going sporadically. But 3 in a month. I told him to take them POS off and get another module. Worked fine. Tested his wires and 2 were 100,000 ohms or better. Thats after 8 months!!! Lets see $85 for the wires + $60 for modules. Hmmm... are those accells really worth it? Aggrevation was priceless.
So I recommend any wire EXEPT accells for a reason. RETAINING SANITY!!!!
Hate mail from accell groupies please apply here!
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
