new cam
Old Mar 17, 2001 | 12:16 PM
jester731's Avatar
new cam
exactly what is needed to replace my stock cam (88 iroc tpi auto). i know nuthing about cams so i just wanted to know what i would have to replace and how would i know what cam would be best for my car. any help would be appreciated thanx
Old Mar 17, 2001 | 02:44 PM
custman87T/A's Avatar
Right now I am stockpiling parts for my cam swap but I am very **** about things so everything will be new...gaskets,sensors,a/c lines,alt,waterpump,hoses,belts,machining the heads,cam,lifters,rockers, pushrods,headers and cat...there is of course all the standard tune up parts to go along with that...you don't have to go as crazy as I am but I feel that since you are taking it apart and doing lots of hours of labor why not spend a few hundred dollars more and put new parts back on instead of old tired ones. If you are on a restricted budget you will need a cam, lifters(you can reuse roller type),push rods,gaskets and you really should replace your valve springs lots of people don't then wonder why they have problems or poor performance from a more aggressive cam. Hope this helps you.
Old Mar 18, 2001 | 02:03 AM
Dan87IROC-Z's Avatar
Custman hit it right on the nose. While you are in there, you might as well spend the money and get everything running well.
You will need the cam, new springs, retainers, valve seals, gaskets for the heads, intake, timing cover, and all the smaller ones through there, a new timing chain set, gasket sealant, thread lock, and like what was mentioned above, anything else you think you want to improve. Expect to spend about a week or more and spend about $500+.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.625" 10 Bolt with 3.42s soon to come!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
