How much will a new TPI Plenum cost??
Old Mar 16, 2001 | 02:25 AM
Dan87IROC-Z's Avatar
How much will a new TPI Plenum cost?? Mine has a stripped bolt so I need to get a new one to get the runners and plenum to seal right!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 16, 2001 | 03:15 AM
Ski89Z28's Avatar
Can't you just drill it and tap it a little larger? Then just get a new bolt for that one. Cheaper and quicker that getting a new one.
But if you want a new one just try getting a used one in the classified here like I did. I got one for $60.00, yea it isn't ported but it is good.
Old Mar 16, 2001 | 05:10 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
If that doesn't work, take it to a welding shop and have them fill the hole and then re-drill and tap. If you are at the right swap meet those go pretty cheap. I think you'd be better off fixing yours.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 16, 2001 | 09:28 AM
Steve89GTA's Avatar
Just drill it out completetly (off the car of course) and retap. Done!...use the next size up bolt.
Old Mar 16, 2001 | 11:28 PM
93ND500's Avatar
Just Heli-Coil it. That way you have all the same size bolts.
Forgot this: You will need a kit for M8-1.25 thread.
[This message has been edited by 93ND500 (edited March 16, 2001).]
Old Mar 17, 2001 | 11:13 AM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Heli-coil it man! Why buy a new one when you can fix your old one so easy? Heli-coils are stronger than the aluminum originally was, so fix it and you will be in good shape!
[This message has been edited by TPI79MC (edited March 17, 2001).]
Old Mar 17, 2001 | 11:31 PM
Vader's Avatar
Heli-Coils require a special tap and installation/cut-off tool if you want to do the job correctly. Steel thread inserts use a standard tap size, are stronger than Heli-Coils, and don't require any special installation tools. If you have room for a full insert, I'd suggest that over a Heli-Coil. If there is not much wall area around the damaged hole, a coiled insert may be the next best thing.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 20, 2001 | 12:40 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Dan,
Email me about your plenum. I might be persuaded to fix the thread for you if you consider having me port your plenum at the same time! If it cant be fixed (it probably can), I'll sell you a ported plenum in exchange for your bad plenum.
I have one sitting here that's freshly powdercoated in gloss black.
Daniel Burk
MantyZ28
16
Dec 21, 2015 11:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
