High Compression 305?
Old Oct 2, 2007 | 08:55 PM
Tempest22's Avatar
Car: 1989 Camaro
Engine: 406, Patriot Head, Comp Cam
Transmission: 5 spd
Axle/Gears: 3:73 Posi
Here's my problem, I recently purchased an 85 Camaro 305 TPI motor for my 89 camaro. I cleaned it all up and painted it, when I went to take a compression test all of the cylinders had over 200lbs of compression. I had the motor semi-apart to put a new timing chain on it, still had the plastic one. So I'm guessing that nobody messed with it. Anyone got any ideas?
Old Oct 3, 2007 | 10:04 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
Re: High Compression 305?
maybe you didnt line the timing marks up correctly and the valve timing is off
Old Oct 3, 2007 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Doesn't sound like anything's wrong to me.
Old Oct 4, 2007 | 09:16 PM
Tempest22's Avatar
Car: 1989 Camaro
Transmission: 5 spd
I'm not saying there is anything wrong with it, I'm just curious to why this motor has that kind of compression when nothing was done to it. As for the timing being off, the motor fires and runs fine so I don't think that is a problem. Plus if the timing was off I don't think the compression would be so even across all the cylinders.
Old Oct 6, 2007 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The actual numbers on the gauge don't mean a whole lot.
Old Oct 6, 2007 | 11:22 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, just that it's consistant. my 9.5:1 c/r 305 put out 190lbs. my 10.2:1 305 puts out like 230+
Old Oct 6, 2007 | 08:01 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
run the cast numbers on the cylinder heads on mortec
Old Oct 6, 2007 | 11:23 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
That is so true. The actual reading is a function of your static compression ratio, the condition of your rings & valves, and the timing event of the camshaft.
A fairly mild camshaft will produce a fairly high reading at low rpms but if you installed a longer duration camshaft; it will produce a lower reading just because of the "valve overlap". Even though they have the same static compression ratio.
So, as Apeiron/Chris stated, the actual reading does not have much meaning as there is a wide range of factors that affect the actual reading. It's the consistency between the cylinders that matter more.
Old Oct 7, 2007 | 08:03 AM
ScotSea's Avatar
The "valve overlap" is more a secondary effect of valve timing in this case. I think what you meant to say was the closing point of the intake valve has a huge effect on cranking compression. The intake valve closing point is at the opposite end of the intake lobe ramp as the overlap period. So a lot of intake valve cam timing will delay the intake closing, and therfore probably raise the overlap period (depending on the cam's LSA).
Scot
Old Oct 14, 2007 | 12:00 AM
TIMSLOST92's Avatar
HI I HAVE THE SAME SITUATION. I BOUGHT AN 87 305 TPI. AND ALL BUT TWO OF THE CYLINDERS MEASURED OVER 200 PSI WHEN I RAN A COMPRESSION TEST. I DID A LITTLE MINOR VALVE ADJUSTING. AND THEY ARE NOW ALL BETWEEN 205 AND 210 PSI. IT WAS RUNNING GREAT WHEN I GOT IT. SO I HAVE NO PLANS TO PULL THE HEADS RIGHT NOW. I READ THAT CARBON BUILD UP CAN CAUSE HIGH READINGS. BUT FROM WHAT I CAN SEE IT LOOKS PRETTY NORMAL. I PLAN ON INSTALLING IT IN MY 89 TRANS AM NEXT WEEKEND. GOOD LUCK WITH YOUR PROJECT. ---------------------------------------- TIM ---
Old Oct 14, 2007 | 11:03 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
190-215 psi is NORMAL for a 305. Most 305s of that era had 9.3-9.6:1 compression.
Old Mar 16, 2021 | 11:31 PM
MY89IROCZMYPAST's Avatar
How’s the Trans Am today Tim?
quisterio
Jul 28, 2006 08:48 PM
Josh91Bird
Carburetors
May 8, 2006 08:46 PM
anesthes
Nov 4, 2004 11:56 PM
Mark A 91Formula
Feb 2, 2002 11:41 AM
