Get rid of the peanut Cam.
Old Feb 22, 2001 | 04:05 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Just to let you all know I did a cam change over the past few months. I also ported the plenum, intake, and runners; installed a true roller timing chain, and a AFPR. The cam is out of lt-1 motor, specs@.50 418/430, 194/199, lsa 111. O'man what a difference, the car pulls to about 5200 insteed of 4500, power you can feel. So if you are crused with the peanut cam, get rid of it. Track opens on March 31 let you know what happens.
87 Z28 305 TPI, Auto, LT-1 cam (peanut is history), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, rapid fires, and 170* Stat.
Old Best 15.414 @ 87.47.
Old Feb 22, 2001 | 04:27 PM
The ODB's Avatar
As much as I love small duration camshafts I have to agree. The peanut is great for emissions and fuel mileage but terrible for power.
I mic'd mine at only .225" lift (intake)at the lobe which equates to only .337" lift at the valve (less than the advertised .350" intake lift).
I never even bothered checking duration with a degree wheel because it was being replaced anyway.
I still keep the camshaft in a box in case I ever have trouble passing an emissions test.
ODB
Old Feb 22, 2001 | 07:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
What LT1 engine is that out of? A Caprice or Impala? Thats not a C/F or Corvette cam. Congrats on your swap!
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 23, 2001 | 04:51 AM
TorchTA's Avatar
I've been wondering about that myself...
Anything to keep the guys from calling the 86 the peanutmobile.
-JT
Old Feb 23, 2001 | 06:39 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Its out on an Impala SS I belive.
Old Feb 23, 2001 | 06:50 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Those specs look like an aftermarket L98 replacement cam from Crane or someone like that. Those specs (durateion) in fact are smaller than the L98 SD cam. Lift is about the same but it has a narrow LSA.
I do not believe it is a GM cam as GM tends to use a wider LSA (114-117) on its cams.
Old Mar 21, 2001 | 12:29 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
</font>
It's a stock GM hyd roller cam. I know.... I have one in my '94 Caprice LT1 9C1.
The cam specs are .418"/.430" 191d/196d i/e at the valve with (stock ratio) 1.5 rockers. The LSA is 111.5 d.
The cam was used in ALL B (Caprice, Roadmaster, Impala SS) and D (Fleetwood) body LT1 engines, 1994-1996 model years. The 1996 cam specs are a little different (.414"/.428" lift) but essentially the same.
I think the same cam is, or was, used on some of the L31 Vortecs 1996-1999 and perhaps on some of the present crate engines. A quick look at GM Powertrain website and/or SDPC will confirm this.
The F/Y car cams LT1 and LT4 are different in that they have more lift and duration, but larger LSA.
I have suggested the use of the Bcar 94-96 LT1 cam as a replacement for LO3 and LO5 pre-1994 Caprice owners, and I'm glad to see it being used as a modest & inexpensive Fcar replacement cam here. FYI.
Now can anyone help ME find the thread that showed the photos of the Vortec to TPI base manifold mismatch? I thought they used to be here, but I've searched to infinity and beyond with no luck. TIA.
- Ken... Fcar lurker, a Bcar owner
'94 LT1 9C1, 4400# and 14.96 @ 92.5 mph corrected for MSL, basically stock, dual kid seats, cooler, trunk gear, 7X6 spotlamp, TU6 Caddy flash-to-pass, 6J6 deck lights, and this spring, the Astrovan overhead console.
Old Mar 21, 2001 | 03:36 PM
Dan87IROC-Z's Avatar
Then what are the specs of the LT1 Cams in the Y/F bodies?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 21, 2001 | 08:54 PM
Kevin91Z's Avatar
http://www.f-body.org/tech/4th_gen.htm#camshafts
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
