Which cold air kit?
Old Oct 3, 2007 | 10:16 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Which cold air kit?
Looking for recommendations on a CAI.
89 GTA 350 car.
Old Oct 4, 2007 | 09:25 PM
Notplayn's Avatar
Re: Which cold air kit?
So everyone is running their original air filter box
Old Oct 4, 2007 | 09:40 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
check out the technical articles...they have a few articles to point you in the right direction
Old Oct 4, 2007 | 09:48 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
89 GTA 350 car.
I pieced one together from Pepboys. It cost me 50 or 60 bucks to put together. Nothing fancy, just a knock off K&N filter, with some chrome plastic. Looked pretty cool, but I went back to the stock look, and got the parts off a junk yard trans am.
Old Oct 4, 2007 | 09:52 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
SLP Cold Air Induction Kit is probably your best bet for something pre-made. You can check out a link here; http://www.slponline.com/view_produc...06&BIG=21006-1
I currently have one for sale, PM me if your interested.
Old Oct 4, 2007 | 10:25 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
+1 for the SLP CAI. I have it on mine and looks almost stock if that's what you're going for. Don't buy a new one though. The minimal gains aren't worth the $300 that SLP wants for it. I got mine used on ebay for about $70.
Old Oct 4, 2007 | 11:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
SLP or homemade are really your only options. I dont know of any others.
Old Oct 5, 2007 | 11:35 AM
RF88GTA's Avatar
Car: 1988 GTA
Engine: 383 STROKER
Transmission: TH350
Axle/Gears: 373
I PUT A K@N FILTER IN MY STOCK AIR BOX, AND CUT THE SIDE AWAY FROM ENGINE OUT. THE FIREBIRDS ALREADY HAVE COLD AIR IN THEM, SO USE YOUR MONEY ELSE WHERE.
Old Oct 5, 2007 | 11:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Here's another
http://www.fbodymotorsports.com/inc/sdetail/1760
The only other alternative is to install one of the aftermarket 'glass hoods with the "WS6 Ram Air (Cold Air)". They give the cleanest & most direct flow to the TB.
Old Oct 6, 2007 | 12:26 AM
Kevinn's Avatar
Car: 1992 Z-28 25th Ann Edition.
Engine: 5.7 TPI
Just order something from slp.
Old Oct 8, 2007 | 10:20 AM
EGG's Avatar
EGG
Car: 88 Trans Am
I've never really understood this, for the sheer number of 3rd gen's on the road, there's no decent off-the-shelf CAI's?
This is an OTR type (over the radiator) CAI on a LS1 in a commodore sedan. I'm getting pretty tempted to see if I can fit one of these under the hood of the T/A.
I still find it hard to believe there aren't any options other than "make your own", "$300 box with a hole and a SLP sticker", pod filter, or replacing the hood?
Old Oct 8, 2007 | 01:17 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I bought one of those eBay ones and am putting a universal K&N 3 inch filter on it. Eventually I am going to build a box for it too. On the 91-92 Firebird's and T/A's I would love to see something that has 2 vents in the fog light and park light vents. Sorta like this:
On both sides though.
Old Oct 8, 2007 | 03:26 PM
Kevin91Z's Avatar
Cold air kits didnt become popular until the 4th gen LT1 came out. The thirdgen Camaro and Firebird setups are pretty good for stock stuff. The LT1's were not as good. By the time the cold-air kit market took off, thirdgens were left in the dust. Now there isnt enough interest for someone to build something new and market it with success.
Old Oct 9, 2007 | 08:57 AM
RF88GTA's Avatar
Car: 1988 GTA
Engine: 383 STROKER
Transmission: TH350
Axle/Gears: 373
I HAVE A 88 TA GTA AND THE GUY I BOUGHT IT FROM HAD A 4" DRYER HOSE PIPED DOWN TO THE FOG LIGHT. ONLY THING IS FOG LIGHTS GOT TO COME OUT, BUT IT DID WORK GREAT. I AM GOING TO SAVE MY MONEY AND GET THE RAM AIR HOOD KIT.
Old Oct 9, 2007 | 09:14 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I didnt mess around, I'm into show and a little go.
So the SLP was perfect. Looks awsome and you can feel the difference.
Plus it was easy to install.
Old Oct 9, 2007 | 10:21 AM
EGG's Avatar
EGG
Car: 88 Trans Am
That's a good point... I didn't think really of the fact that you've had a lot of engine changes in GM-NA; LB9/L98/L03/L05, LT1/LT4/LT5, LS1/LS6/LS7/LS4/LS2, now LS3
Over the same time period in aus we've had 304/355, LS1/LS2 and L76/L98 V8's in the local sedans.
I'll see if I can measure one of these up sometime, not sure what I'd do about the MAF though, or if there's enough hood clearance.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
