Timing on an '85 Iroc
Old Mar 17, 2001 | 11:24 AM
Kulkat 63's Avatar
At what degree should I time this '85 Iroc at? Or do I pick up the timing mark through the probe hole?
[This message has been edited by Kulkat 63 (edited March 18, 2001).]
Old Mar 18, 2001 | 02:07 AM
Dan87IROC-Z's Avatar
First off you will need to loosen the distibutor hold down bolt so you can turn your distirbutor to the desired timing. Then dissconnect your EST connector. The EST is located just above the AC and Heater blow boxes in the back passenger side corner of the engine compartment, it is a brown and black wire the comes out of the main wireing harness. Then hook up your timing light to the battery and the #1 plug wire, as close to the plug itself as possible. I usually mark the timing mark on the harmonic damper with some chalk so its easier to see with the timing light. Then start your engine and turn your distributor until you see the correct timing reading on the balancer. Then shut off the car, disconnect the timing light and tighten down your distributor. Hope this helps!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.625" 10 Bolt with 3.42s soon to come!
Old Mar 20, 2001 | 08:46 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Dan,
Everything you said was correct, except for the ESC connector. The 85's used the coil in cap type coil with a 4-wire connector behind the distributor you have to disconnect. Also, the timing should be 6 degrees BTDC.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Old Mar 22, 2001 | 04:47 PM
Kulkat 63's Avatar
6 Degrees - would that also apply to the 305 engine like mine? Since everyone who responded seems to have the 350.
Old Mar 22, 2001 | 06:53 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
<font face="Verdana, Arial" size="2">Originally posted by TransamGTA350:
Dan,
</font>
Dan is right also, but it's not the wires you disconnect here, it's a vacuum hose connected to the distributor. This will give you your base timing reading, and set it at 6 degrees.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 22, 2001 | 09:19 PM
bowtiez's Avatar
My 85 z has disconnect for timing above heater box as stated. Where is the difference or are years not standerdized.
Dan,
</font>
Old Mar 23, 2001 | 12:13 AM
james_fearn's Avatar
My 85 Z also has the brown disconect by the AC box. I have a coil-in-cap but do not have a vacuum advance.
James
Old Mar 23, 2001 | 12:35 PM
Car: '89 GTA
Engine: ZZ6TPI
Ok, maybe it's a tuned-port thing having the wire by the heater box. In that case, yes, you should disconnect that wire since you don't have the 4-wire connector. My old IROC had the coil in cap and the 4-wire harness, but it was a carburated 305. All tuned port engines were 6 degrees btdc.
Magnaflow cat-back,
K&N open element,
BlueIroc-Z
Jun 9, 2019 03:22 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
