Throttle Body
Old Mar 22, 2001 | 01:52 AM
robert1's Avatar
Throttle Body
Can someone tell me where the crossover lies for a 52mm vs. a 58mm? Whats the minimum for the 58? Would it be overkill on a 355", 330hp? Thanks
Old Mar 22, 2001 | 10:58 PM
JETHROIROC's Avatar
You shouldn't need a 58mm TB, since I'm pretty sure even the RamJet 502 uses a stock 52mm TB and puts out well over 330hp. Spend your money elsewhere, IMO.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 22, 2001 | 11:02 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The 502 uses a 48mm TB, which is stock for the L98.
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
Old Mar 23, 2001 | 12:21 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its my opinion that you only need a 58mm for a SuperRam or Miniram, or if you're running a blower or nitrous. With a stock-style TPI intake, 52mm is fine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 23, 2001 | 12:28 PM
91RedBigFinZ's Avatar
Are you sure about the 48mm stock l98 TB? I thought it was close to 52mm.
'91 Z28 50,000 miles:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, coil; Hypertech rotor, cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts.
Old Mar 23, 2001 | 01:00 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 91RedBigFinZ:
</font>
stock 305 and 350tpi have a 48mm tb.
Old Mar 27, 2001 | 05:46 PM
irocbob89's Avatar
48 mm is stock
robert1- you need a 52mm tb
i have the hollie 58mm for my application
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
