mini ram install problems....help
Old Mar 27, 2001 | 05:50 PM
irocbob89's Avatar
ok i am having a Hell of a time putting my engine together. I dont know which vacum lines to put in the 4 holes they put on the mini ram. that is problem #1
the second on is, the throttle cables the braket that comes on the mini ram is on an angle and rubs the pieace on the tb. when it rubs it will eventually brake the cable, what did you guys have to modify or adapt to the mini ram in your installs? thanks for the help
Bobby
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Old Mar 27, 2001 | 06:33 PM
irocbob89's Avatar
ttt
Old Mar 28, 2001 | 12:49 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
There should be a black bracket and a silver bracket provided for the cables. The silver one needs to be used for the accelerator cable because of the angle problem. It mounts on top of the fuel rail so the cable is angled down towards the throttle body. The black bracket on the side holds the TV cable and cruise control cable. For the vacuum lines . . . you can get fittings at Pep Boys. If one isn't used than plug it closed. I used all four though . . . PCV valve, brake boaster, fuel pressure regulator and there was another line on the passanger side that needed hooked up.
'89 Formula 383 TPI
Old Mar 28, 2001 | 02:44 PM
irocbob89's Avatar
thank for the input, i found the silver bracket in the garage last night, i finnally figured it out. thanks for the help. I found what all the holes are for to.
Bobby
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
1.6rr
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
