TPI conversion
Old Mar 29, 2001 | 06:07 PM
EPSracing's Avatar
TPI conversion
I have an 87 TPI setup complete the only problem is its a MAF setup can i convert this to run speeddensity without having to buy a new computer? maybe just changing the chip and some other things?
Old Mar 29, 2001 | 09:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The MAF computer and the Speed Density computer are completely different. To change, you need the computer, the PROM, the wire harness (or re-pin yours), the knock sensor, the MAP sensor, and various other little things.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 29, 2001 | 09:50 PM
89bonestockiroc's Avatar
I too am planning to convert to speed density. It is looking like its not that hard to do. I was scanning the archives here and i found that you can get a 730 computer from a 90-91 lumina, beretta, grand am, and a couple of other cars. If you can pick one of those up out of the salvage yard it shouldnt cost that much. You just have to get a memcal with eprom from the 90-92 camaro. I dont know if the wiring harness from any of those cars will work though, im trying to find out. I really hope one will work because those harnesses are hideously expensive new. Anybody know if a harness off of a lumina or something will fit?
Old Mar 29, 2001 | 10:39 PM
Steve R's Avatar
I have a Lumina. As far as I know, the MAF is different, and there are 6 injectors instead of 8. Other than that I think most of the GM harnesses were the same, but dont quote me on that. All I know is when I look under the hood of my Lumina, all I see are wires everywhere, and I Dont even have ABS.
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old Mar 30, 2001 | 05:44 PM
cfabe's Avatar
The comptuers are the same in the lumina-body cars and the 5.7 TPI. The injectors on these setups batch-fire (each side fires all 4 injectors at the same time) so the 6 cyl 8 cyl makes no difference. The only difference is in the prom. If look, you will find a 4 pin connector from the ecm harness to the injector harness, that is 2 pins for each side.
I would think that the harness would have the connectors at different places, or would have different lengths, but they may be close enough that you can just modifiy the harness from the ecm donor vehicle.
As far as the maf being different, i dont know about that. Mave the v6 uses a maf with a lower cfm range.
[This message has been edited by cfabe (edited March 30, 2001).]
Old Mar 30, 2001 | 08:25 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
GM Tech over on sethirdgen.org told me the same, the ECM's listed above are the same as the 90-92 TPI, and much cheaper out of the yard then if you pulled a "camaro performance" part.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 31, 2001 | 07:55 AM
EPSracing's Avatar
so let me see if i take a computer from a 90-91 lumina and plug it up to my harness it will work for speed denstiy as long as i change the eprom. or do i have to buy a harness from a speed density car?
Old Mar 31, 2001 | 10:18 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
There is no way a harness from one of those cars will work. Everything would be in the wrong position, and would not bolt into the car.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Mar 31, 2001 | 12:16 PM
R.O.B.'s Avatar
What if we did grab the correct computer, what else is needed to convert. Do we need to completely rewire the system, or can we just modify our existing one. Anyone have an indepth article on this?
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Mar 31, 2001 | 06:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Rob, I did give a list of "donor" cars, but the Lumina wan't on that list. The Lumina is a "W" body car, along w/ the Cutlass, Regal, and Grand Prix and the computer WILL NOT work. The computers on these cars are mounted under the hood, behind the passenger side fender. Because of this, GM had to re-design the ECM to be waterproof, so the ECM has the 4 square connectors like the Vette.
You also cannot use the wiring harness from any of the V6 donor cars. You can, however, re-pin the existing wiring harness, providing you ****** the connectors along with the 1227730 ECM from the donor car.
I plucked mine from a Corsica. It MUST say 1227730 in the ECM. There is one similar looking to it, but I don't know if its the same. Then you will just need to get a PROM for the vehicle the ECM is going into. I used a '91 T/A chip as a starting point, and custom burned it to fill my needs.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 31, 2001 | 09:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by EPSracing:
I have an 87 TPI setup complete the only problem is its a MAF setup can i convert this to run speeddensity without having to buy a new computer? maybe just changing the chip and some other things?</font>
You can use the australian 808 code in your existing ecm, but it's not that great od system, going to the 730 is the best answer. Pep boys will have some extra terminals for adding a few wires. No big deal just takes some time. Get some wiring diagrams, from the DIY_EFI.ORG incoming area and you'll see how easy it is. Might even just do some reading at the Prom burning area and see how others have already done it
Old Mar 31, 2001 | 09:58 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Dyno Don:
</font>
that's why they invented soldering irons and heat shrink tubing.
Couple guys have made adapters so most of it at the ecm end is just a PnP for the ecm.
lt1z350
Aug 28, 2015 05:57 AM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
