Anyone see a problem using this cam on a 355TPI???
Old Mar 31, 2001 | 08:45 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
OK, first I'm gonna start by saying that this is the cam I have chosen and I know that there are better cams out there! I'm NOT looking for a reply such as "that cam sucks, go with (insert cam here)" or "why that cam, it sucks", etc. etc.!! I am looking for constructive opinions here! Mainly, WILL THIS CAM WORK??
The cam I'm looking at getting is the XE262 cam which has a 218/224 duration and a .462/.469 lift!! The engine it's gonna go in is a 355 TPI with Dart Iron Eagle Heads....TPI is stock but plenum has been ported and SVO 24# injectors have been added!! MSD 6-AL has been added as well!! Also, when I do the cam change I'll be buying an EdWright Fast Chip! Now....does anyone see a problem with using THIS cam?? Also, the cam is ground on a 110 LSA and I'm thinking about getting it ground on a 112 or 114 LSA instead because that's what TPI likes and it will also help my fuel mileage!
Old Mar 31, 2001 | 09:30 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
It will work.
Old Mar 31, 2001 | 11:59 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
It will work, but you don't have to come on so strong. I understand that some thirdgenners out there will badmouth any part they deem less than perfect, but as long as it's done constructively with a reason behind it, why get mad? One thing though, some people say a part sucks because they put together a mis-matched engine, change the part and then it runs great. So they assume the part is worthless. I just study the info and I become judge. Not trying to lecture you, just giving everyone a little 'view' of why some opinions are what they are. But anyway, that cam will be fine.
Old Apr 1, 2001 | 12:27 AM
Thanks dhirocz!! I understand what you're sayin' but the last post I put up on here got over 50 posts and 90% of the posts were arguements about some formula and whether or not a 750 carb would give you worse gas mileage than a 600 carb when all I simply wanted to know was whether or not the 600 would WORK on my engine! LOL! I just wanted to avoid crap like that in this post! Sorry if I seemed so rude!
Old Apr 1, 2001 | 12:45 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I can't resist.............."that cam sucks, go with (the LT4 Hot Cam)" ..........hehe j/k man!!!!
Old Apr 1, 2001 | 01:36 AM
<font face="Verdana, Arial" size="2">Originally posted by Matt87GTA:
I can't resist.............."that cam sucks, go with (the LT4 Hot Cam)" ..........hehe j/k man!!!!</font>
LOL....thanks! I've actually heard about that cam a lot!! What exactly are the specs on that cam?? Duration @ .050, Lift, and LSA!! Just curious!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 TPI, Stock TPI ported, 24#/hr SVO injectors, Hedman Shorty Headers, Dart Iron Eagle heads or GM LT4 heads, XE262 Cam ground on a 114 LSA, Moroso Blue Max Plug Wires, external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Apr 1, 2001 | 10:23 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
LT4 cam is 218-228 .050 duration .495 .495 lift with 1.5 rockers, .525 lift with 1.6 rockers. That cam along with many others like the ZZ9 would be a better choice for your combo.
Old Apr 2, 2001 | 04:13 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
I have a zz9 that i got a great deal on ... so that is the cam i am gonna use in my vortec 350...
not because i think it is great... but because it is what i got...
later,
Chris
Old Apr 3, 2001 | 01:43 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
Also out of curiosity what separation angle is the LT4 cam?
Old Apr 3, 2001 | 01:03 PM
rwelch's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86TpiTransAm:
The cam I'm looking at getting is the XE262 cam which has a 218/224 duration and a .462/.469 lift!! The engine it's gonna go in is a 355 TPI with Dart Iron Eagle Heads....TPI is stock but plenum has been ported and SVO 24# injectors have been added!! MSD 6-AL has been added as well!! Also, when I do the cam change I'll be buying an EdWright Fast Chip! Now....does anyone see a problem with using THIS cam?? Also, the cam is ground on a 110 LSA and I'm thinking about getting it ground on a 112 or 114 LSA instead because that's what TPI likes and it will also help my fuel mileage! </font>
86TpiTransAm, would like to hear how this works out because I am going to retrofit my 56 running this cam (110 lsa) w/87 TPI and 89 ECM.
Old Apr 3, 2001 | 04:14 PM
rwelch.....you've got mail!
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
