Anyone using a TB spacer for TPI?
Old Mar 31, 2001 | 05:42 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I saw this at thunderracing.com. I'd never heard of it before, but a buddy of mine said he put it on his TPI and felt a major difference. Is anyone using one? Is it worth the money?
Old Apr 1, 2001 | 08:53 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Thats interesting. Makes the plenum about 1/2 longer. Wonder what it does to the throttle/tv/cruise cables?
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Apr 1, 2001 | 09:23 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
well it does more than just extend the plenum if you look into the TB bores thier swirled.it supposed to cause a swirling afect for the incoming air
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Apr 1, 2001 | 01:08 PM
91RedBigFinZ's Avatar
It comes with a bracket to re-locate the throttle cable. The only problem i had was with the length of the wires for the IAC on the throttle body. I had to splice new wires in. it may of had something to do with my slp runners being wider than the stock ones. Doug
'91 Z28 - 50,000 miles. All power options leather. 350 TPI:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Dual factory Cats; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts; smog pump delete.
S Cobra Radar Detector; Z28 SS Floormats
Old Apr 1, 2001 | 03:12 PM
RyanSS's Avatar
What kind of gains did you see?
SOTP feel?
Old Apr 1, 2001 | 05:51 PM
I did that mod and underdrive pulleys simotaneously, so its hard to tell the exact gain from the spacer. Doug
Old Apr 2, 2001 | 01:00 AM
88IROCs's Avatar
Ok, I understand how a spacer can improve airflow in a wet system(carb or TBI) and swirling the mixture may help to keep the fuel suspended, but I don't understand how this device would help a TPI system. Maybe someone can enlighten me but, I thought the object of TPI was to get air from the TB(and onwards) with as little disturbance as possible. This device(and I use the term loosely) seems to defeat that purpose.
This is not meant as a flame, but in my mind something doesn't add up. As for the claims of a 'real noticeable difference', well let's just say I've heard that about a lot of products that didn't deliver the goods(at least for my cars).
Colour me skeptical. I've said it before: if it does what they say it does, then at least show me a dyno graph.
[This message has been edited by 88IROCs (edited April 01, 2001).]
Old Apr 2, 2001 | 09:56 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I wonder if it shapes the air, similar to an airfoil?
Other than that, only thing I can see it doing is adding more plenum volume.
Old Apr 2, 2001 | 10:49 AM
91banditt2's Avatar
Engine: 5.7 HSR
i'm with 88irocs.the(possible)gains you would see don't justify the cost.i'm guessing it probaly costs around $70 to $80.
Old Apr 4, 2001 | 02:59 PM
89GTA5spd's Avatar
Just buy a NOS 5151 kit and and bolt it on.. the plate extends the plenum exactly like that thing... but unlike that plate it shoots fuel/n20 into your intake and will actually make your car faster. I wouldn't waste your money. Get a set cheap headers instead.
I think easy bolt on things like that and airfilters/airfoils/pulleys sell so well because you think wow.. for 15 minutes of work/less than $100 i can get 10 hp! But you rarely get the results you want. I have a K&N cone filter, and an airfoil on my car... but neither made a big difference. Porting the intake actually did though.
hmm.. now I just need to get a set of headers/y-pipe..
89GTA5spd
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Apr 14, 2016 08:52 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Sanjay
Aug 12, 2015 03:41 PM
