What is the fuel pressure regulator set to stock from GM on a TPI engine??
Old Apr 1, 2001 | 09:42 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Just a couple questions!! First, is the fuel pressure regulator for a 305 TPI and 350 TPI set to the same psi or different from the factory??? Second, what psi are the fuel pressure regulators set at from the factory for both 305 (and 350 if psi is different)!!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Soon to upgrade to a 355 TPI, Stock TPI ported, 24#/hr SVO injectors, Hedman Shorty Headers, Dart Iron Eagle heads or GM LT4 heads, XE262 Cam ground on a 114 LSA, Moroso Blue Max Plug Wires, external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
Old Apr 1, 2001 | 10:01 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I think they are both 40 psi stock
'89 Formula 383 TPI
Old Apr 1, 2001 | 10:21 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The factory rail mounted non adjustable regulator will normally maintain between 40-43 psi at idle. When you first accelerate it will drop from 3-5 psi and then re-stabilize. This is the standard regardless of engine size, the injectors are sized per the CID.
Old Apr 2, 2001 | 12:52 AM
Mike635's Avatar
5.7 35-39/5.O 42-46
Old Apr 2, 2001 | 08:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My 350TPI is 37 PSI and 47 PSI at WOT
Old Apr 2, 2001 | 08:46 PM
Todds1987iroc's Avatar
At idle my 305 LB9 is 46 PSI
Old Apr 2, 2001 | 10:01 PM
black5.7GTA's Avatar
I believe the 85-87 350's were set at 39-42.88-92 45-48.Both my 90 Vette and GTA,had 48psi stock.
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's
G-tech 0-60 5.1 1/4mile 13.6@104
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
Old Apr 2, 2001 | 10:38 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I believe GM spec is 43.5 psi. I'm not sure if all are the same, though. This is at idle, assuming you don't have vacuum leaks.
Old Apr 3, 2001 | 02:59 AM
I've heard someone say something about unhooking a vacuum when adjusting an adjustable fuel pressure regulator!! What vacuum is supposed to be unhooked when you're setting your fuel pressure regulator???
Also, does anyone think there would be a problem with using a stock fuel pressure regulator with 24# injectors on a 355?? Will a stock one work or should I get an AFPR???
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Old Apr 5, 2001 | 02:06 PM
Greg's Avatar
You're supposed to disconnect the vacuum going to the fuel pressure regulator. The fuel pressure varies by vacuum.
'89 Formula 383 TPI
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
