LT4 Hot Cam question......
Old Apr 9, 2001 | 02:48 PM
Stang Eater's Avatar
just wondering if it will work good in an L98 with stock heads(for now), and if i could go to 1.6 roller rockers with that cam, after i do more intake work, or would it be better to go with the ZZ4 cam and then add the 1.6 rr's, cause im pretty sure the zz4 with 1.6 will work.any ideas??????
mods in sig
91 Z28, White on Red
TPI 350, Rebuilt heads,K&N's, MSD Wires, Accel Supercoil, Accel Ign. Module, MSD Cap and Rotor, Edelborck T.E.S headers, cat!,custom 3" with 80 Series Flowmaster, 3" stainless tips, Jaz seats, B&M Megashifter, Alpine stereo system,17" Eagle 203's
Old Apr 9, 2001 | 04:11 PM
Dan87IROC-Z's Avatar
Either way you go, you will need new valve springs anyway. I am using the LT4 HOT Cam in my car now, its too big for the way the car is equiped currently. I wouldn't use 1.6 rockers, that brings the lift of the LT4 HOT Cam to .525", which is pretty drastic for a 350 with stock heads. If I was you, I would go with the LT4 HOT Cam, but keep the stock ratio rockers. If you want to go a step up, you can do what I did and get some 1.52 roller rockers from Comp Cams ($200), but I think 1.6s with either cam is too much.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 9, 2001 | 08:36 PM
thanks man, im eventually gonna buy new heads and do intake work, but i guess with knowing that the lt4 with 1.6's will work with them after, and without them now, that'd be my best bet, thanks for the info
f-bodyz28
Sep 2, 2015 05:03 PM
masonta
Sep 1, 2015 06:40 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
