IAC Questions
Old Oct 22, 2007 | 08:46 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
IAC Questions
Okay, even though I generally consider myself well-versed in cars (how they work, etc), one thing I cannot seem to figure out is the idle air control (IAC), so I have a few questions that I need help with.
A) What exactly is it?
B) Where is it located?
C) How does one know if it is function correctly (What are some examples of a possible malfunction IAC)
D) How is it adjusted/removed/installed (Is it benificial to modify/adjust it from the stock position for a performance gain, if so, to what extent)?
Thanks.
Old Oct 24, 2007 | 11:58 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: IAC Questions
By doing a search, it took about 5 seconds to find this...
https://www.thirdgen.org/forums/tpi/...ir#post2003454
Apparently the link isn't working, so do a search for "Idle Air Control" in the TPI forum and the first result should explain everything you've asked.
Last edited by formula_novice; Oct 24, 2007 at 12:00 PM. Reason: Automerged Doublepost
Old Oct 24, 2007 | 05:47 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Re: IAC Questions
Well, I just attempted to adjust it, considering my car idles at 1200 RPM - and nothing happened.
Old Oct 24, 2007 | 07:48 PM
MdFormula350's Avatar
Re: IAC Questions
let the car get full warm in park, with everythng hooked up
turn it off, then turn the key to on for 10 seconds but dont start it.
then turn off the key and unplug the IAC connector, its right under the tps on the passenger side off the throttle body.
then start the engine, the engine w/o being computer controlled idle wise should idle 500 rpms give or take 50+- if it doesnt you need to manual turn the screw to open or close the thorttle blades to get it to idle at this rpm first.
here follow this guide to adjust the idle.
https://www.thirdgen.org/tpimod2
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
