ALDL differences , MAF/MAP?
Old Apr 14, 2001 | 08:16 PM
leirch's Avatar
What are the differences in the ALDL pin config from MAF to MAP, if there is any at all.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Apr 15, 2001 | 10:42 AM
Vader's Avatar
Leirch,
Among the cars in any given year, I don't believe there are any connector wiring differences. The TBI and TPI cars have teh same pinning. The only differences would be the use of terminal "F", for either the TCC relay or SHIFT lamp on an auto or manual transmission.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Veaceonee
Sep 29, 2016 08:15 PM
69GTOby
Apr 18, 2016 02:34 PM
greenyone
Sep 8, 2015 08:41 PM
J.C. Denton
Sep 8, 2015 05:35 PM
Gunsbee
Sep 7, 2015 07:10 PM
