Pulled off the plenum today and.......
Old Apr 16, 2001 | 11:57 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
found that the inside was covered in soot and smelled like gas.... we were told this was caused by mechanical timing problems. True??? OR is it normal. Whats the best way to get all the carbon/soot out anyway?>?
How can I stop it from getting BACK in there???
Thanks,
Tony
Originating member of the SJNEP Crew "Welcome to Understated Sounds and Performance"
Rice..It's whats for dinner!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Tony
Check out www.transamgta.com
"What does not kill us only makes us stronger"
Old Apr 16, 2001 | 12:02 PM
Synergy's Avatar
Whoever told you that is an idiot
The soot is from the exhaust gases that pass trough it. They come from the EGR ports right at the entrance in the plenum. I guess the only way to keep that from coming back is to disable EGR. Now gas shouldnt be in there. I guess the only way it could have gotten in there is trough the EGR ports or from the gas tank vapor recovery canister. Maybe you can try changing the filter on that. I'd all this is pretty much normal. I've looked at a lot of plenums and they were all dirty inside, including the runners. Now, mine's clean because I don't run EGR anymore, but I could care less if it's clean or not. That's my 2 cents on this
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Apr 16, 2001 | 12:03 PM
jRaskell's Avatar
I believe this is caused by the EGR, which cycles exhaust gases back into the intake to facilitate full burn of the fuel. You will inevitably get some buildup of soot, but it shouldn't be excessive if the EGR is functioning properly.
Synergy's Avatar
As far as getting the soot out... go buy a couple of cans of carburator cleaner and spray it all in there. That will clean it pretty damn good.
Old Apr 16, 2001 | 12:05 PM
jRaskell's Avatar
The smell of gas in the plenum could be an indicator of the engine running rich, as there would still be fuel in the exhaust gases that get routed back through the plenum. I would expect some odor to exist even when the car is running properly tuned.
Old Apr 16, 2001 | 04:31 PM
IROCZ88's Avatar
Carb cleaner or access to a parts washer will clean it up.
Old Apr 16, 2001 | 08:02 PM
Vader's Avatar
...and in three months it will all be back again. No air filter is 100% effective in trapping all particles and moisture. Once the moisture hits the hot walls of the plenum, the little spec of dust that the water droplet was encapsulating will bond to the wall when the water is evaporated. A few million more specs of dust glued to the walls of the plenum, along with a good dosage of evaporated fuel and oil vapors every time you shut off the warm engine, and the dust and dirt will be baked on really well.
The buildup isn't even a problem unless it is about 1/8" thick or more.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 16, 2001 | 09:00 PM
Guest
Guest
Posts: n/a
The joys of a tuned intake...
Unless you have a leaky valve, or one of the above maladies, you are experiencing the normal reversion from a tuned intake setup. There is enough shock wave returning up the intake to send some fuel vapor flying the wrong way, and thats where the gas smell is coming from. I have seen this on every TPI I have had apart, some to a lesser extent than others probably due to valve sealing issues. The intake I cut to death with a mill no longer has this problem. I cleaned the runners and plenum before I swapped the intake on, and 4000 miles later there was no trace of fuel, and very slight buildup from the EGR. The base however still had some fuel and more buildup than the rest of the system, so its stopping there rather than heading back up the runners and into the plenum.
Generally its more of an annoyance than a problem. Just keep the TB and IAC area clean, and it will be fine.
Old Apr 17, 2001 | 11:30 AM
fly89gta's Avatar
Car: 2018 Camaro SS
thanks guys u put my worries to rest.....the buildup wasn't really that bad it was the smell of gas that worried me but its all good now...did some mild porting(Thanks Vader great write up on that) and clean it all up
Member of the Jersey Fbody Crew(JFA)
Moderator at www.transamgta.com
Tony
Old Apr 17, 2001 | 11:41 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Man, all you EGR soot haters, lol. Don't forget that the PCV system use the EGR passages to dispers, so on top of what vader and max mentioned, there is also crankcase oil vapors constantly being run through there, which i imagine is a better glue than any of the aforementioned funks.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
MantyZ28
16
Dec 21, 2015 11:02 AM
86IROC112
Aug 31, 2015 07:00 AM
Thaney9
Aug 29, 2015 03:16 PM
TheExaminer
Aug 26, 2015 04:59 PM
spaigo
Aug 21, 2015 07:46 PM
