having some terrible surging what could cause this??
Old Apr 21, 2001 | 02:13 AM
hookin88formula's Avatar
tonight i got the car out was driving along at bout 30 mph in 1st gear and i noticed a slight surge what could cause this? any explanation would be great thanks
1988 firebird ws6 formula350tpi ascd ram air hood GT AUTO 4th gen spoiler black paint with blue pearl centerline champ 500 16x8 all around potenza 245 50 16 on front and 27x11.5 16 mickey thompson sportsman pros on the rear(real sticky!!) msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light A pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter vette servo custom ram air system with a 9" K&N cone filter tb coolant bypass slp runners polished plenum and runners 170* thermostat smog pump and a/c delete plus cat delete march underdrive pullies, tpis airfoil cvr high torque starter (love it) aluminum drive shaft
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system new sticky tires coolant by pass smog removal new runners new thermostat and new three core radiator since i would get to the line and be well over 220* aluminum drive shaft and vette servo
Old Apr 21, 2001 | 11:19 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Fuel filter?
92 RS, 350, Street & Performance MPFI, TFS heads,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Apr 21, 2001 | 08:18 PM
precision350's Avatar
Explain more in detail
Old Apr 22, 2001 | 01:49 PM
it feels wierd like it has power then it loses power. its like after it gets over that surge it has more power.. it does it though all the gears. i was wondering if maybe it could be the timing at what is optimal timing??
Old Apr 22, 2001 | 04:50 PM
86TransAmTPI's Avatar
I had a similar problem with my 86 Trans Am i have now.The problem wound up being my MAF sensor.Apparently the filiament wire inside was broken.Just my personal experience.
Al in NJ
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
Old Apr 22, 2001 | 09:44 PM
The Man's Avatar
I am have the same problem with my 92 Z28. I know what is wrong with it, just haven't had time to fix it. Below 2500rpms is trash(like you have a larger cam in it or like a torque converter clutch in switching in and out). It is the distributor. The poll piece in it. I have seen a few act like that. it is the worst arouns 1400-1800rpms(light loads). under power it goes away.
Old Apr 22, 2001 | 09:52 PM
could it also make my car act like it has a stall converter in it? cause today it was surging just the same as ever then it started acting as if maybe it has a stall and its stalled around 2000 rpm but then sometimes it doesnt act like its stalled so how much for the distribitr part that u were talking bout do i need a whole new distributor or just the pole piece thanks
Old Apr 22, 2001 | 10:39 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
When it surges, does the RPM go up or down? I know this sounds like a dumb question but it would help to know.
Old Apr 22, 2001 | 11:49 PM
when it surges the rpms go up
InfernalVortex
Apr 20, 2021 11:31 AM
BrianI
Oct 3, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
banksGTA
Sep 13, 2015 11:56 AM
