What motor oil do you use?
Car: 1985 Trans Am
5 quarts Mobil 1 and a PF-25 filter for my LB9.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Kevin Irving
I use Mobil 1 fully synthetic motor oil 10W30. I would only use recomend using synthetic oil if you have new valve seals. The synthetic oil will drop right down into the chambers if you have bad seals. This will cause you to burn about 2 quarts of oil per 3000 miles. When this oil costs about $4.50 a quart, thats a lot of money you are throwing away.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
Car: '89 GTA
Engine: ZZ6TPI
My L98 takes 5.5 quarts. I know the spec is 5 quarts, but the spec is the same for all V8's with or without the oil cooler. So I guess the oil cooler holds .5 quarts.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
<font face="Verdana, Arial" size="2">Originally posted by Dan87IROC-Z:
</font>
</font>
Rick
'88 GTA 350 Full of Leprosy (rust)
Full Exhaust, Free mods, Xtreme Energy cam, Intake Pieces and 2100 RPM TQ
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
</font>
</font>
castrol GTX here 10/30 or 10/40 depending on time of year........
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
1985 trans am
4 wheel disks
16 inch wheels
305 TPI
t tops
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
The #1 motor oil, Royal Purple.
I dont use it yet cause my engine is eating some oil already, but once I do my heads and put new valve seals in ill be using it, as long as my rings look ok
Until then i use 10W/30 Pennzoil, they best non-synth oil u can run
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
</font>
</font>
Guest
Posts: n/a
Since Pennzoil changed to pure base it is the best conventional oil. As far as the Mobil 1 not smoking as much as conventional oil past the valve seals it shouldn't. I don't remember why. I used to have a 1985 BMW K100RS motorcycle and when I left it one the centerstand it smoked terrible. The dealer said to put Mobil 1 in and it would stop. I did, and it did, he was right. I remember having it explained why it worked but I forgot.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by FlashGTA:
As far as the Mobil 1 not smoking as much as conventional oil past the valve seals it shouldn't... I don't remember why... The dealer said to put Mobil 1 in and it would stop... I remember having it explained why it worked but I forgot...</font>
KAM
(by the way, my L98 has lived on Pennzoil all its life without any problems. The intake and valves, etc. were spotless last year when I had the top half opened up. I know - shoulda done the valve seals then...)
ill second that formula8!!
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'll third it!
I've been using Mobil 1 oil since I had about 70k miles on my IROC, and now I have over 131k miles and it still isn't burning or leaking oil and the oil pressure is 45 cold and 30-35 hot. I'll be pulling out my 305 to swap in a 355 over Memorial Day weekend, and I'll tear apart the 305 to see how clean inside it is.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
I'm tossing this in the general tech/engine dept. because this really don't have much to do with TPIs. Plus, you may get more responses.
-Bill
-=1987 Buick Grand National=-
Almost Jacked Up Like a Mother
*CC 218/218, ported and polished heads (1.77, 1.50), Accufab AFPR, custom DP by Custom Tubes,
Walbro 307 hotwired, Big Mouth cold air intake, 009s, custom PROM and 20psi of fury*
Wanna try me?
-=ICON Motorsports=-
Modertor TPI board
-Bill
Wanna try me?
Modertor TPI board
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
