Cam Swap
Old May 7, 2001 | 06:40 PM
MouseCamaro305's Avatar
Cam Swap
l've got a next generation performance catalogue and l've been looking to swap the cam in my 1990 IROC-Z 305 TPI the description of one of the two cams lve been looking at are as follows:
cam 1: 50-state-legal stock 305 1200-1500 RPM range, ADV DUR: INT-260 EXH-260, Dur .050 INT-252 EXH-252 Lift: INT-.444 EXH.444 its a comp cam and it's "computer compatible." does that mean you can install it and go? or will there have to be some mods and tuning done? does anyone know what kind of idle l'll get out of it? just as smooth as stock or a little rougher? will there be a significant amount of gain considering it's a stock 305 w/ runners and 150 shot nitrous and an exhaust system? any info on this cam would be greatly appreciated
thanks a lot guys
Old May 7, 2001 | 08:05 PM
BadBowtie88's Avatar
Since your car is speed density instead of mass air, your car will not idle well at all if you install a cam. I don't know everything about it, but, I do know that you can't install a cam in a speed density car unless you switch over to mass air. Hope this helps.
1988 Iroc-Z
L98 350 TPI
700R4 Tranny
2.77 gears(will change)
Mods: Crane CompuCam, headers, gutted air boxes
Best e.t.: 14.49@95.5mph
60ft.@2.27(was 2.12 w/o cam)
Old May 14, 2001 | 02:13 AM
Greenshamrock77's Avatar
You can put a cam in a SD car, but you are going to have to burn a custom Prom. Plus I have to recomend the ZZ4 cam. It will work well with your engine as long as you reprogram the computer. It will also work very well with nitrous. Nitrous does not like overlap (neither do FI cars) and it likes big exhaust duration. The ZZ4 cam has both of these qualities and is only $170 from Jim Pace performance parts.
www.paceparts.com
Their catalog is free too, I recomend it, it has a lot of stuff.
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph!
[This message has been edited by Greenshamrock77 (edited May 14, 2001).]
Old May 14, 2001 | 04:36 AM
Synergy's Avatar
Bull****. I have a pretty healthy cam in my SD TPI car and it idles just FINE with a stock chip. How the hell do these rumours come out anyway ? lol
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
[b]
Click here to see pics of my car !
Old May 14, 2001 | 10:38 AM
synergy- did you have to reprogram anything when you installed the new cam? did you do it yourself or have it professionally done? how much did it cost you altogether after it was running and everything? any noticable power gains?
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
