FINALLY. an alternative to Miniram/Superram
Old May 9, 2001 | 07:46 PM
89ROC's Avatar
I recently got a job at a local speed shop. Well this guy brought his 93 Turbo Mustang Coupe up there (960rwhp street car! ). He used an Edelbrock carb manifold. It was plumbed for fuel injectors, and had custom fuel rails. There was an elbow that bolted up where the carb is supposed to be. It turns out this guy is an engineer, and will do the same set up for my IROC for only $425,!! I have to buy all the parts of course. This setup utilizes a Ford TB and GM sensors. I think this should easily get my car into the low 12's on motor, finally. Man, I am stoked!!
I know this is a long shot, but does anyone here have this set-up?
BTW-I will post pics and dyno results after this is all done.
So far, with the bone stock TPI manifold I've pulled 254rwhp/347rwtq.
-Jason
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
[This message has been edited by 89ROC (edited May 09, 2001).]
Old May 10, 2001 | 09:45 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You are aware of the accel pro ram intake that is exactly what you are describing, except it's complete with all the stuff you need for about the same $425. A single plane intake with rails and injector bosses, etc.
...ed
Old May 10, 2001 | 09:47 AM
BadSS's Avatar
Wilson manifold gets $450 to convert an intake to EFI. There are intakes by Holley and Accell that look like they would work fine for the majority of EFI builds for a lot less than that. Check out this link http://www.mrgasket.com/dfinew.htm Accell has an elbow adapter that you can use a GM throttle body. I think the Holley intake is a lot less than the Accell - it's at http://www.holley.com/HiOctn/ProdLin...901-101-1.html
Old May 10, 2001 | 12:28 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Lignefelter already makes the elbow you are describing and fuel rails come with it...
I am trying to set up my FTP site with the pics of the new intake that is going on...
Weiand single plane intake, Lignefelter elbow, and 58mm throttle body
Old May 10, 2001 | 07:03 PM
89ROC's Avatar
I was not aware that anyone else actually converted the carb manifolds to EFI. I'd like to see some pics when you get them up. Thanx for all the links and info!
[This message has been edited by 89ROC (edited May 10, 2001).]
Old May 10, 2001 | 07:42 PM
89ROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
...ed
</font>
Actually the setup im describing is totally different. If I was to use the Accel superram base, I would then have to buy the plenum and runners for an additional $700, because thats the only way to get air into the engine with that base.
That is exactly what I'm trying to avoid. The setup I described totally eliminates the need for a base/plenum/runners. It's set up just like a carb, but EFI.
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
13.87 on the G-tech
Old May 11, 2001 | 12:31 AM
90 Z28SS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 89ROC:
</font>
The Accel Pro Ram is carb style intake plumbed for EFI and nothing like the super ram .
Derek 90 IROC 5.7
Mods: All the usual bolt ons siamesed base , 2500 stall , 373's , SS hood ,big and littles , lotta reduced weight. Stock heads/rockers , cam ,runners , chip and TB
Best Et: 13.12@101 ...1.701 60 ft.
Old May 11, 2001 | 12:22 PM
raven350's Avatar
Engine: 5.7L
My new intake setup....
http://albums.photopoint.com/j/Album...a=12888672&f=0
Old May 11, 2001 | 01:17 PM
90 Z28SS's Avatar
Yep . thats the Pro Ram with the TB adapter , very saweet
Do you mind me asking how just the intake and elbow was . Ive only seen it listed as a complete kit with DFI and harness for like $2400 .
Derek 90 IROC 5.7
Old May 11, 2001 | 02:53 PM
Guido's Avatar
Car: 2000 Trans Am
Here is blown96SSragtop's car from MFBA car club. He lives in IOWA.
Looks pretty good to me!
-86 IROC
Jacked up like a mother!
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
[This message has been edited by Guido (edited May 11, 2001).]
Old May 14, 2001 | 04:15 AM
raven350's Avatar
Engine: 5.7L
Intake, elbow, fuel rails, and throttle body cost right around $1000.
A lot better than what a super ram and miniram cost even without the throttle body.
You just can't beat the price....
Old May 15, 2001 | 11:15 AM
89ROC's Avatar
Where do I get that adapter elbow? Anyone know the part number? I wasn't able to find it on the Accel DFI website.
TIA
[This message has been edited by 89ROC (edited May 15, 2001).]
Old May 18, 2001 | 08:35 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I have a question. Where does the bracket for the throttle, tranny's tv cable, cruise control attach to? In your pictures i dont see any holes drilled & tapped for the factory bracket that supports these cables!
Old May 18, 2001 | 08:40 AM
86Tra/maro's Avatar
Ohh! I forgot , How much are the Intake, pre set-set up fuel rail & TB adapter elbow priced seperately
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old May 18, 2001 | 09:07 AM
89ProchargedROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 86Tra/maro:
I have a question. Where does the bracket for the throttle, tranny's tv cable, cruise control attach to? In your pictures i dont see any holes drilled & tapped for the factory bracket that supports these cables!</font>
you have to fab that up.
Old May 18, 2001 | 11:54 PM
Steve R's Avatar
What kind of RPM's can you get out of those things? That thing looks SICK!
How much for just the base and elbow, provided I can use my stock throttle body and injectors? Even if I have to buy everything all brand new, that's an amazing price for that kind of setup!
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Old May 19, 2001 | 12:35 AM
IrocStan's Avatar
http://www.holley.com/HiOctn/ProdLin...MSM/f5954.html
Here's the link-^ I give up on getting the pic to show.
How come nobody uses or talks of this? I'd like to make a plenum for the top then bolt the throttle body on the front. A poor mans miniram. I have also seen this manifold in a catalogue complete with the plenum, fuel rail etc. No price was listed though. The manifold alone goes for around $240 at summit. It appears that the hole for the injectors need machined though.
87 IROC 350
13.94@103mph
Check out my new web page.
http://austinsiroc.homestead.com/Home1.html
[This message has been edited by IrocStan (edited May 18, 2001).]
Old May 19, 2001 | 03:00 PM
86 IROC's Avatar
OK, this is all great. But, does anyone have any cold hard dyno #'s? I've heard a lot lately about how some people are caling the Mini Ram a piece of crap. They reccomend a Carb style intake w/ a 4bbl TB and 8 injectors. A few years back I was lloking into fabricating my own elbow that resembled the Accel unit. But, I want dyno comparisons before I go pulling my car apart! Any help/info would be greatly appreciated. Thanks in advance.
Old May 20, 2001 | 03:10 AM
Tas's Avatar
Tas
holley. $255 according to summit. add $50 for TBI to carb adapter plate. add $150 for 454 TBI without injectors. I dunno if TPI rails work on it or not. you guys can check/
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited May 20, 2001).]
Old May 20, 2001 | 09:35 AM
89ROC's Avatar
I found the Accel manifold (part no 74139)with fuel rails for $435. It's RPM range is 2000-6500rpm. The Holley (part no 9901-101-1, pictured above) is 2000-6000rpm. I want something that goes to at least 6500rpm, so I'm definately buying the Accel piece. The only other piece I'll need the the elbow, which I've been able to find for $230.
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
13.87 on the G-tech
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
