MSD, Accel or Crane?
Old May 15, 2001 | 05:05 PM
ScreaminDeamin85Z's Avatar
which one do yall like and how do they perform? i was leaning towards the Crane Hi-6s but wasnt sure about the others. anyone used the others before? MSD digital 6 and the Accel setup.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old May 15, 2001 | 05:54 PM
poncho9789's Avatar
I have the accell 300+ ignition on my formula and when I hooked it up I noticed a mark improvement in performance,millage,and idle quality. The accell comes with a rev limiter and coil. The accell is also smaller that the other units which makes it easyer to mount.
Hope this helps
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler, this car is currently under rebuild and restoration.
Old May 16, 2001 | 01:03 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I would get MSD.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 16, 2001 | 10:39 AM
Kyle F's Avatar
Got to give a plug for what worked for me
MSD in my and my brothers cars, love em.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old May 17, 2001 | 01:36 PM
ok i have it down between Accel and Crane, because of ease of install. has anyone tried the crane system?
Brandon
Old May 17, 2001 | 07:32 PM
ttt
Brandon
Old May 18, 2001 | 10:07 AM
Kyle F's Avatar
The MSD is super easy to instal, I had it doen in 15 minutes, just buy the plug in harness and you wont even have to splice wires.
Old May 19, 2001 | 02:21 AM
which MSD? the 6a or the digital 6?
Brandon
Old May 21, 2001 | 10:32 AM
Kyle F's Avatar
The 6A is what I used
Past Thirdgen:
Old May 21, 2001 | 11:55 AM
lb9formula91's Avatar
go with the msd 6aL with the rev limiter
91 formula
305 tpi
342 Rear
borla cat back
white face gauges
home made cold air
tpis airfoil
crane afpr
msd 8.5 mm wires
msd cap and rotor
AC Delco Rapid Fire plugs
soon to have ported plenum and intake
We light the tires, so we can fight the fires!
Fighting the "RED DEVIL" on the southside of bethpage!
Old May 23, 2001 | 10:26 AM
Kyle F's Avatar
Save some money and don't get the rev limter, you don't need it unless you car is a manual transmission.
Old May 23, 2001 | 12:52 PM
87iroczmd's Avatar
i have the crane hi-6s, it came with built in rev limiter and an adapter harness, it plugs in to your coil wires and into your coil, and then you ground one wire, it was the easiest install, but you have to advance the timing afterwards cuz it retarts it like 20*, well worth it, and it is very small and easy to find a place to mount, get it!!!!
Old May 23, 2001 | 03:51 PM
irocbsa's Avatar
I know this is not one of your choices but I use the Mallory HyFire IV with the promaster coil setup on my machine. I have always wondered why I don't see a lot of people with the same setup. It has worked beautifully for me.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 23, 2001 | 04:07 PM
BLOWN85/TA's Avatar
Get the Accel unit, much better than many out there. If MSD would fix the stuff sent in for repair I would reccomend them, but they dont so I will never own another MSD product. Jacobs also makes some good stuff. I use the Accel 300 system.
Old May 23, 2001 | 04:56 PM
Zackpak's Avatar
I used Accel (see sig), and it has been flawless for 2 years. Got the billitech distributor a few months ago as well. I can't really comment on others, but my throttle response went from good to great. Did not expect to feel the difference, but I did. Milage also improved slightly. Installation is very easy too. For the money it cost, I'm very satisfied.
'88 Formula/305/Ported & Polished TPI
Poly's all around
Accel Super coil/Billet Dist/8.8's/Bosch+4's
Long way to go . . .
Gearing up for 350HO/t56 swap-in over summer.
Old May 23, 2001 | 09:16 PM
<font face="Verdana, Arial" size="2">Originally posted by irocbsa:
</font>
heh thats the exact same setup my bro's use on their camaros! i just wanted to be different from them and branch out. it is a good setup though, just not what i was looking for. thanks though.
Blown85/TA i know what you mean my bro sent one of his boxes out to them over a year ago and come to find out that they never fixed it and sent it back to use in the same condition.
Brandon
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
