XFI280
Old Dec 6, 2007 | 02:48 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
XFI280
Who has made good power with 355cu XFI280 and Super Ram?
Old Dec 6, 2007 | 02:52 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: XFI280
might get better reponse in the alternative intake board
Old Dec 9, 2007 | 11:00 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: XFI280
I have a flat tappet xfi280 in my 383 with a lt1 intake.
Results below
Old Dec 9, 2007 | 11:59 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: XFI280
the superram idk if it would peak with the xfi280, the supperam has how much of an operatiing range? i doubt 6000. the 355 with the xfi280 will want to REVVVV! id say 6000 with no prob and its really gona depend on your heads as well. match the heads/cam/intake together
i got the XFI280 for my HSR 383 and ive been porting the HSR, and im using patriot195cc heads. im hoping for peak power to be 5500-6000. the only reason why its peaking that low is becasue its a 383. im hoping for 480-500hp at the crank
your 350 will rev even more.
Old Dec 10, 2007 | 12:15 AM
AUS-IROC's Avatar
Car: 1986 IROC Z
Engine: Nothing but air
Axle/Gears: Four stands
Re: XFI280
What are the patriot 195cc heads like? I have just ordered a set. I am going to be using an XFI cam but haven't decided weather to wait and stroke the motor to 383 or just run a 350.
Old Dec 10, 2007 | 12:28 AM
Car: 87 TA clone
Re: XFI280
they are good castings, good quality, and they are light lol
i had the dual roller spring upgrade for .670 lift, the 5 angle valve cuts, and CNC bowl blend, they came with vitton seals, stainless valves and hand porting..
they looked really good, i didnt even know that ported the intake and exhuaust runners untill i looked in with a flash light. im very happy with them. where did u get them from? i got mine from skips white performance for 860 shipped to my door.
the 195cc patriots that flow 260-270cfm will really really rev on a 350. ur peak will be 6500-7000 unless u punch it out for more cubes. the cam will depend on ur intake/head combo.
Old Dec 10, 2007 | 12:48 AM
AUS-IROC's Avatar
Car: 1986 IROC Z
Re: XFI280
I got mine through an e bay store here in Australia. I paid $1400 shipped.
alloy heads over here generally cost from AUS$2000 to AUS$3500 so I think I got a good deal. I had my springs upgraded to suit the roller cam and I beleive mine have the CNC bowl blend and five angle valve cuts.
I'm running a TPI with 58mm throttle body, CNC ported plenum, SLP runners and I will be gettung a better base manifold. Even with all this the intake won't rev to 6500-7000rpm. Thanks why I think the 383 might be the way to go.
Old Dec 10, 2007 | 03:12 AM
Car: 87 TA clone
Re: XFI280
with your upgrades it seems that ur TB is alil too large, i woulda went with a 52mm, ur TPI even tho upgrades is prob peaking at 5200-5400 depending on the port job of the plenum, runners and base, stock tho ported to stock SLP runners and upgraded base will give u 5200rpms. thats on a 350.... if u put that on a 383 those 33 extra cubes is gona lower that peak RPM even more. id say 4500-4700 like stock. good news is that ur gona be making a butt load of torque, so i hope u got a strong drivetrain and lots of tires.
port the **** outa the plenum, gut the runners completely and port and extrude hone it all and u got 6000rpms! but thats $$$$ muchoooo$$$$.
i would look into a 52mm TB, ur RPMS arent high enough/ intake isnt flowing enough for a 58mm TB, 52mmTB will flow 900cfm dry flow, most 383s run with 750-850 wet flow carb... thats really like 650 dry flow. so the 52mm will give u more and better throttle response and increased power.
vettemanc486
Aug 6, 2015 12:12 PM
Rob's 92 gta
Jul 6, 2015 09:21 PM
Rob's 92 gta
Alternative Port EFI Intakes
Jul 4, 2015 02:53 PM
robertfrank
Feb 12, 2013 02:36 PM
Cody Ashby
17
Jul 29, 2011 11:27 PM
