This is making me angry ( ignition)
Old Dec 8, 2007 | 02:04 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
so a few days ago my gta would cut out and have no power and a sparratic tach. sometimes if i hit a bump the power would come back and tach would be mint
So i went to autozone today and had myn tested.. it was fine.. but i got it warrantyed anyway.
Installed it car runs like when the icm before would cut out
I thought maybe i crossed a wire, Wrong ,firing order was perfect 18436572
Cap was tightened down, timing wasnt moved, Module was snugged down and pick up coil connector clipped in
im just trying to think of something i could have moved or touched
any ideas?
Old Dec 8, 2007 | 02:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: This is making me angry ( ignition)
Bad pickup coil?
Old Dec 8, 2007 | 03:40 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
brand new
Old Dec 8, 2007 | 08:08 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Bad grds?
Might want to stick your head under the dash and take a sniff at the ignition switch to. They tend to stink once they start to burn
Mine drove me nuts. Car would shut down and 10 minutes later everything had power. So by the time you got the tools out to test it was okay again.
later
Jeremy
Old Dec 8, 2007 | 10:03 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
thats an interesting idea. Although the thing is with a bouncing tach its got to be ICM
Or pick up right?
The pick up pulses the icm, the icm is known good so it has to be the pick up even though its like 2-3 months old
while im out there tomorow ill sniff the ignition switch
Old Dec 8, 2007 | 11:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The tach is driven off the coil primary, so all kinds of misfire can cause it to bounce.
Old Dec 9, 2007 | 11:14 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
pulled dist out
ohmed pick up coil its 800 ohms- good
im going to toss another distributor in there and see how it works out
Old Dec 9, 2007 | 12:17 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
so i made sure my old dist. was good put it back in
adjusted timing
running crappy
So, i think to myself based upon how its acting
and i take my hand and hit the passenger side panel under the dash
BOOM, car runs mint.. lol
Ecm must be junk and i have a spare in my other car
thanks for the help guys
Old Dec 13, 2007 | 06:28 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
with the engine running crappy perform a case ground test for the ecm. good ground with negative test lead and positive lead on ecm case while engine is running poor. shouldn't be more than .01 volt. check for loose pins before putting the "new" ecm in. just some advice to keep from chasing the problem after installing the ecm.
Old Dec 14, 2007 | 12:57 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
it ended yp being the ecm connector not clipping in, i ziptied it lol works great
BRoss99
Aug 10, 2025 05:08 PM
Out-Cast
Mar 22, 2019 09:39 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
