What did you all make your homemade ram-air for IROCs with?
I thought I'd use dryer tubing, but the hardware store didn't have any that was big enough, any ideas? Also if anyone could post some pics that'd be great.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I took 2 4" dryer vent caps took out the flapper and installed them into the bottom of the air boxes.Next thing I'm going to do is run flex duct from foglight opening to dryer cap opening.
BD3
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,Dan Burk ported intake system,,March
pulleys,Accel 8.8wires,ign.mod,Crane PS-91 coil,Crane HI-6S ign.box
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors.polygraphite bushings
"The more I learn about women,the more
time & money I spend on my IROC"
BD3
Thanks guys, where did you get that tubing from, 90Z28SS?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Try a place that deals with only Hoses , tubing , hydralic and high pressure hose ect. The stuff I got is beefy black rubber , 6" diamter and its got a spiral steel core , in other words the wind wont mangle it like that aluminum crap <- been there , done that .
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Dan,
I went to HQ in Virgnia Beach but any place like Home Depot or Lowes should have what I used. I went to the plumbing dept and found rubber sewer bellows/90deg pieces etc. I did a 90deg bend from the plenum to a piece of 3" dia PVC piping (just fit under hood and above the stock radiator hose) then where the cruise and charcoal cannister set on the driver side I did a 90 deg turn down. Then I found a plastic pass thru used in wood working shops to hook vacuum hoses up to. I drilled a 3"diam hole thru the battery tray that sets on the passenger side and connected my 90 deg rubber bellows to the plastic pass thru I bolted and sealed to the tray. Then under the car, I removed the vacuum ball for the cruise and attached my K&N cone filter. I even built a little scoop to funnel air up into the fender.
I sold this to Jon Brandt (brandtmann@aol.com) He mas still have it laying around. I since upgraded to the dual SLP cold air unit. When I drag raced I pulled the K&N off and installed dryer duct out the front of the car, making an instant cold air/ram air. I know that not using a filter is bad, but so is dragracing and I never let anyone get in front of me to kick up dirt!
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
8" Air conditioning duct. Its very sturdy. Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Fastchip;
Manual fan switch;
What do you use to attach it to the fog light tubes and air filter housing?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
The tubes are in there really snug there not attached at either end and they havent budged a bit in 2 years . The tubes are so big I doubt very much it would make any difference at all sealing them to the airbox.
IMissMy86TA
Aug 31, 2015 08:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
. I got it at a hose supply store , $12 in total..ching!
