fuel rail question?????
Old May 29, 2001 | 07:17 PM
poncho9789's Avatar
I am currently in the process of rebuilding my tpi car. I want to paint the fuel tubes leading into the fuel rail and the regulator. I was wondering if there was any way to remove the tube in the passanger side fuel rail. Also has any one used the TPIS adjustable fuel preasure regulator, If so have you had any problems with it?
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Old May 30, 2001 | 12:24 AM
rondubbs's Avatar
DO NOT get the tpis afpr.. its a piece of junk, the vacuum port breaks off very easily.
Old May 30, 2001 | 06:34 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
do what i did and tape off the fuel rail and just paint the hard lines it'll be easier
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 30, 2001 | 01:00 PM
poncho9789's Avatar
yea I decided to do that I called tpis and they told me that the hard lines were pressed fited in the fuel rails thanks. I would still like info on brands of fprs.
Old May 31, 2001 | 12:32 AM
KW87GTA's Avatar
I believe I have a crane cams AFPR, and it works well. There is only one small problem, but I have a feeling you will run into it any. The little screw that comes out of the top of the regulator is quite difficult to turn especially if the car is running, it came and touched the TPI on my car. Might not for you, but you can solve it with a little grinding. The quality seemed good, and the price is right. I would stay away from TPIS IMHO cause they just seem to make overpriced, low quality items and then try to make them sound like the best. Don't mean to insult anyone, but just my opinion. Good luck.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Superram, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Accel 24lb Injectors, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant
Old May 31, 2001 | 12:16 PM
Scott C's Avatar
I am in the process of painting my fuel tubes also. I just wrapped the rail in a plastic bag and then taped off the rest. You can't remove the tubes themselves. I also polished the rails with Mothers mag & aluminum polish and they look fantastic!! Very easy to do...takes maybe an hour.
I have a Holley afpr and it looks great. It has a large ribbed "disk" that you turn by hand to adjust the pressure. I've heard others say that the Holley was the best, so I got one too.
[This message has been edited by Scott C (edited May 31, 2001).]
Old May 31, 2001 | 12:35 PM
BryanJ's Avatar
I think I heard holley had a good fpr, but <U>DO NOT GET TPIS<U> it is a waste of good money my vaccum port broke off real easy.
Old Jun 1, 2001 | 10:27 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
The Hypertech AFPR is a nice unit.
Part # HYP-4002 ~ $74.69 got mine from Summit.
Old Jun 2, 2001 | 09:30 PM
GeneralHazzard's Avatar
make your own. thats what i did. theres a artice around somewhere that tells you how to do it
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
