Will this hurt how my car performs?
Old Dec 22, 2007 | 08:43 PM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
I am not shure how deep it goes but the car still peforms GREAT runs like a champ(Needs tune up) and starts every time. like i said im not shure how deep it is i was just looking thrugh my pics of the car and saw that.(The car is not here it is at my moms)..So could you please tell me if this will hurt anything?..what flows thrugh that part of the plenum?
Old Dec 22, 2007 | 08:47 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
Re: Will this hurt how my car performs?
is it just cracked or is it a chunk that is completely broke off
Old Dec 22, 2007 | 09:30 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
i havent seen yet..but it looks like it completly broken off
Old Dec 22, 2007 | 09:34 PM
Car: 87 trans am
well it should make you have a high idle because it is basically a vacuum leak. Could make it hard to tune since the computer isnt seeing that extra air entering the engine therefore the computer would probably be always trying to compensate
Old Dec 22, 2007 | 09:47 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
after the car warms up it idles at about 700-800 rpm
Old Dec 22, 2007 | 10:02 PM
Car: 87 trans am
how long has it been broke like that. maybe the computer has already adjusted to it. you would need to see it you feel any air around that area. if not then its probably not effecting anything
Old Dec 22, 2007 | 10:08 PM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Old Dec 22, 2007 | 10:12 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Start your car and let it idle. Grab a can of carb cleaner or ether or something and give the crack a quick spray or two. If the RPM changes at all then you have a leak and should get it fixed.
Old Dec 22, 2007 | 10:16 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Wait...I don't see what you're looking at?
That looks completely fine to me?
Are you talking about the thing on the top of the plenum?
If so, it's not broken.
That's part of the plenum design...unless I missed what you're talking about...
Old Dec 22, 2007 | 10:34 PM
Car: 87 trans am
ha ha i think your right it is the design of it. it just steps down. i just thought you said there was a crack or something
Old Dec 22, 2007 | 11:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, appears on both sides. You should be OK.
Old Dec 22, 2007 | 11:40 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
What your seeing that appears to be a crack is just a shadow. Had me fooled at first too.
Old Dec 24, 2007 | 11:04 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
lol, Ya i went and saw my car today. There is no crack. Its just a very deciving little shadow. Had me fooled...Thanks for the Help..
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 13, 2015 07:36 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
novaderrik
Aug 10, 2015 12:44 PM
