New Here Couple ?'s About my Third Gen
Old Jan 2, 2008 | 09:05 AM
dj_justice's Avatar
Car: 91 Formula Firebird
Transmission: 4l60
Hey Everyone, Im Dave and I am new to F-Bodys. I just recently bought an 87 trans am with the 305 TPI. I got the car at a police auction for $600. Heres a couple Pics
The motor seems to run strong, burns a little oil but runs good all in all. However i am very disapointed with the cars acceleration. From what i have read these cars run 16's stock in the 1/4. What kind of gains can i expect from changing out the gear set and getting 3.73's? It seems to me that the stock 2.73's might be holding me back. Thanks for listening to my noob ranting.
Old Jan 2, 2008 | 09:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: New Here Couple ?'s About my Third Gen
Before getting into changing gears you should go through everything and give it a tune-up. Change the fluids. Get it running the way it should before modifying it. Modifying it before fixing any problems could cover up a problem that may come back and bite you in the gluteous maximus later.
Old Jan 2, 2008 | 09:19 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Looks pretty decent for the money. You'd notice a big difference by changing the gears, especially that much. Does it have a 9 or 10 bolt rear? It would probably run a lot stronger if it wasn't burning any oil, and doing a good tune up always helps.
Old Jan 2, 2008 | 10:25 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
$600,, thats a great buy! youre wheels alone (refinished) could sell for that much.. and youre motor is an easy mid to high 14 sec car, if its in good tune, with some free mods and a quality exhaust. and then gears. then you we be luvin the tuned port! first on my list would be COMPLETE tune up, and body work. and fixing what it needs first. or u can sell it to me for $400
Old Jan 2, 2008 | 12:18 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Wow, good score! I agree that a FULL tune up should be the first thing you do. Jeg's even sells a pretty decent kit for it including plugs, wires, cap, rotor, coil, and tstat. Check it out HERE:
http://www.jegs.com/webapp/wcs/store...9941_-1_115424
Old Jan 2, 2008 | 02:06 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I believe that's more like a mid to high 15 second car.
Old Jan 2, 2008 | 02:08 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
ive seen plenty 89 lb9's running 13's and 14's n/a. havent you?
Old Jan 2, 2008 | 02:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Not stock. He's stock right now.
Old Jan 2, 2008 | 02:14 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
well i said after , fixing what needs, complete tune up. quality full exhaust and gears.
Old Jan 2, 2008 | 02:18 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
My bad.
Old Jan 2, 2008 | 02:46 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I ran a 15.6 with mine and its the more stout LB9. I had all msd tune up things, 3 piece march pulleys, and a CAI. I think that with a full exhaust and maybe some 3.42's he could break 14's.
Old Jan 2, 2008 | 02:55 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
14 sec lb9 needs = intake, exhaust, gear, traction. 13 sec lb9 needs = intake, exhaust, cam, stall (if auto), gear, more traction. 12 sec lb9 needs all of the following and a power adder.. unless youre 66nova. i think thats his name. im shooting for mid to low 12's with everything in my sig + crane 2032. and 13#'s of procharger.. and a few other things.. and of course it would be a hell of a lot cheaper to build say a 350 to go 12's or 13's but i could always swap out just the block in case of a pop..
Old Jan 2, 2008 | 03:33 PM
dj_justice's Avatar
Transmission: 4l60
I have already replaced the distributor cap and rotor. When it is not so cold out I will change the plugs and wires. I plan on using this as my daily driver for now. This is my race car.
Although I am sure I will be racing the trans am too.
Old Jan 2, 2008 | 03:40 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
sweet, i never saw a monte ss with a lti.. usually tuned ports and carb motor swaps. must smoke the tires like mutherf+++++!!!!!!!
Old Jan 2, 2008 | 04:51 PM
brandotron's Avatar
Nice old man car.
Hahaha, I kid I kid.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
neekolzun
Aug 24, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
