1987 FIREBIRD PROBS>>also any hints on how to "bREAK" into a firebird
Old Jan 3, 2008 | 09:04 PM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
hEY GUYS. i LOCKED MY KEYS IN MY FIREBIRD (1987) Like two hours agoand NEED help on how to get into the car. I am not pating a locksmith 100bucks to get my keys. Any SECRETS" on how to get into the car? Has power locks dont work though so i just use the *****.
Also my car just started giving me probs today. I was driving my fiebird around yesterday for about 3hours put 40 miles on it(City driving.) And today i went down to put a new airfresiner in the car(Mango scented). And while i was down there i figured i would start her. So i did fired up but only went to 500RPM's (*Cold) then 200 then it went up to 600 then 100 then it died. So i figured air bubble(I just put 12 gallonds in it two days ago.)and it fired up went to 100 rpms then stalled all this happened in about 1/2 a second. and that all it does not is start then die. it sound like the fuel pump is pumping cause i hear the little wine when i put it to "On" so any ideas?
Old Jan 3, 2008 | 09:33 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Re: 1987 FIREBIRD PROBS>>also any hints on how to "bREAK" into a firebird
Not sure on the running problem but when i locked my keys in my car at the gas station, a police officer got it open with a slim jim with just a little trouble.
Old Jan 3, 2008 | 09:56 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Lets tell everyone how to break into
are cars
Old Jan 3, 2008 | 10:50 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
The performance shop down the street from where i live, sells a lock opening kit, it has instructions for every car without antitheft systems. Cost $45
It even comes with a key that will open most cars
didnt work on my firebird though (the key). The opener probably will though.
Old Jan 4, 2008 | 03:27 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I remember I did this once after that, I started carrying a flat copy of the lock opening key in my wallet. The way I would "break into" my car is knowing that my windows weren't in the best shape, so I would pull one down about 1/4 to 1/2 of an inch and you can do 1 of 2 things. A) get a coat hanger and fish out your keys or B) with the same coat hanger, fold it in to an "L" shape and try to unlock the car from the inside. My keys were in the ignition, so I just got the "L" rod and kept swipping near the inside door handle until I felt the little lock **** unlock...
ps. How did the Mango Scent work out for you?
Old Jan 4, 2008 | 07:52 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've done that before. Took me 3 minutes to get into it. These cars are so pathetic when it comes to keeping people out. You really should get an extra door key.
You may have gas line freeze.
Old Jan 4, 2008 | 08:24 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Smells Really Nice. In my old camaro i had watermellon that was the best smelling camaro ever.
Also guys i went down today bought me some "Gold" Performance rotor and cap. Some bosh platnum 2 plugs and some red aceel wires. I havent pu the wires or the plugs in yet. But i did put the rotor and cap in. The car starts instatly but if you dont give it any throttle it will die. But if you gice it 1/4 throttle for about 15-20 second it will stay running by it's self and wont die.
Any ideas?
i also got the keys out they where in the ignition so i got a 6 foot long metal hood and cgrabed hem out of the ignition and pulled them thrugh the little space in the window.
Old Jan 4, 2008 | 09:29 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I usually carry a spare in my wallet.
Old Jan 4, 2008 | 09:54 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
sounds like my camaro trying to start up lol.
i had a bad sensor that was screwing things up.
and have you tryed a different key? like another car key?
i did that once to my lst car i had cuz i locked the keys in there. and got a set of different keys and tryed it out and it unlocked it. it was awqesome
Old Jan 5, 2008 | 01:19 AM
HCR13's Avatar
Car: 1987 Trans Am
you might not want to install those Bosch Platinum plugs. I heard they foul out real quick in our cars.. I go with regular AC Delcos and with Champions on my cylinder that burns oil...
Old Nov 10, 2010 | 07:12 PM
My97TransAm's Avatar
  1. Originally Posted by 02 camaro
Any ideas?
you know, i had the problem where my car would shut off if i reved it up than let off the gas, im currently ordering a new intake system for my 97 trans am because of that, turns out my elbow to my intake was cracked, it ran just fine while i was on the gas but letting off it would drop to 500 rpm or just die, which was due to way to much air going into the mixture, so check out ur intake make sure u have no cracks in it, my whole elbow broke in 2, dont ask me how U_u
Old Nov 10, 2010 | 07:14 PM
hey, i had the same problem where if i hit my gas then let off my car would end up droppin to 500 rpm than stall, the problem was i had a huge crack in my intake, so u may wanna check out ur intake system and make sure theres no cracks or holes in it, mine happend cuz the system didnt fit so the hood closed on it pressing it down and i guess the heat just caused it to crack, gl
Old Nov 11, 2010 | 12:30 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Please do the basics first before buying anything and wasting money.
Go buy/rent the fuel pressure tester from Autozone or your local Autoparts store. Costs to buy $50 and is worth it to buy it for future problems. Probably less than the unneeded things you bought for no reason. Get the option of it being a fuel problem then continue testing/inspecting every sensor and ignition component.
Also get some spares, they are worth the $3 investment.
Old Nov 11, 2010 | 08:28 AM
I know its the problem because i turned my car back on when it cut off on the side of the high way popped the hood n seen the crack, i then pushed the elbow together to cover the crack n my engine idle went back up to 1k rpms, roarin like a champ, duct taped the intake to get me back home n she ran like it was 1997 again even hit a victory donut haha
Old Nov 11, 2010 | 08:36 AM
Stephen's Avatar
Car: 87 GTA
AC Delco > Bosch Platinum or those Rapidfire plugs. Nothing beats the AC Delcos, IMO.
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
