305 cam help
Old Jan 12, 2008 | 10:40 PM
335_GTA's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
305 cam help
I would like to do a cam swap in my 305. What the biggest i could go without messing with a stall, or porting my heads.
I will replace the springs, Just looking for some ideas now.
Old Jan 13, 2008 | 12:17 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: 305 cam help
how about an LT1 cam??
Old Jan 13, 2008 | 12:25 AM
335_GTA's Avatar
Engine: 305 tpi
Re: 305 cam help
Cant seem to find one at the moment. one guys has one over on fbody but it takes him days to respond to any of my msg's. And on ebay there always in a whole package with the rest of the valvetrain.
That what I have been looking for in the first place.
So i guess if anyone has a stock lt1 cam that they are willing to part.
Old Jan 13, 2008 | 12:33 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: 305 cam help
theres always someone selling a cheap lt1 cam if not this site check ls1tech all those lt owners change cams and sell them cheap. all you gotta do is ask.
Old Jan 13, 2008 | 03:26 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: 305 cam help
I think I got one stored. I'll have to look.
I'll get back to you. I think it is a 705.
Old Jan 15, 2008 | 03:27 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: 305 cam help
Check on camaroz28.com, that's where I found mine. That sight caters to all generations of F-bodys, so you'll find one in a hurry. I just put out a wanted ad and had one within a week (out of a 97, with 30,000 on it).
Old Jan 15, 2008 | 07:50 PM
Engine: LO3
Re: 305 cam help
one just popped up in this sites classifides yesterday.
Old Jan 16, 2008 | 10:15 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 305 cam help
I have a brand new, never run L31 cam (same as LT1 B-cam except for the shorter dowel at the nose, which is what you'd want anyway). $50+shipping. Or if you're not in a hurry, I could drop it at the shop in Dayton where I go and you can pick it up there.
The LT1-B is ground on a 111 LSA which gives it a better midrange power curve than the LT1 F or Y cams. Would be especially beneficial in a 305 motor.
Old Jan 17, 2008 | 02:21 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 305 cam help
yeah I paid $230.00 for my cam.
So its all in what you want to spend.
Old Jan 19, 2008 | 12:18 AM
Roton86's Avatar
Car: 86 Pontiac T/A
Engine: LO5 + TPI = 14.40 @ 93mph
Transmission: 700r4 + b&m shift kit
Axle/Gears: 3.0
Re: 305 cam help
Hey guys,
new to the forum here, and Im also looking for info on LT1 cams. I got a 94 9C1 caprice engine (350 5.7L) that im going to drop in to my 86 trans-am. Would it be ideal to put an Lt1 cam in there?
Old Jan 20, 2008 | 04:30 PM
Engine: LO3
Re: 305 cam help
if that is an LO5 motor then yes itll be an upgrade.
Old Jan 20, 2008 | 10:07 PM
Roton86's Avatar
Car: 86 Pontiac T/A
Axle/Gears: 3.0
Re: 305 cam help
Yup, it's an LO5 motor. So besides an LT1 cam, what other parts would work good on it?
Should I start a new thread?
Old Jan 21, 2008 | 02:18 PM
86LG4Bird's Avatar
Re: 305 cam help
If it's the original engine in the 94 9C1 and it's a 5.7, then it's an LT1, not an LO5.
Be careful, 94-96 9C1's with the "baby LT1" 4.3 L also exist.
Old Jan 21, 2008 | 03:05 PM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Re: 305 cam help
The iron head LT1 engine will perform about as good as the same 94-96 f body engines if you put the real LT1 cam or the stock LT4 cam in. The big body engines used a much smaller cam, which is the same as the 96-99 L31 cam.
A lot of LT1 people say that the cast iron heads flowed better than the aluminum heads the same years.
GM liked them so much they used the same basic head on the L31 except for the reverse flow cooling system.
Old Jan 21, 2008 | 08:09 PM
86LG4Bird's Avatar
Re: 305 cam help
Heh heh......"The iron head LT1 engine will perform about as good as the same 94-96 f body engines if you".........just leave the cam alone
Because of its superior LSA of 111 deg and installed ICL of 107 deg, it actually outperforms the f/y LT1 cams up through the midrange, whereas the f/y cam's emissions-slanted goofy LSA and ICL sacrifices midrange power just to eek out a few numbers at a 5200-5300 peak versus the b cam's 5000 peak. And there's more to the story: With the same intake and exhaust setups, there's even less of a peak hp difference than the 15-25 hp Chevy advertised.
Old Jan 21, 2008 | 09:17 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
Re: 305 cam help
Why exactly are LT1 cams a good swap over for the 305? I've been thinking about getting a cam for a while now, and now someone in my class is building up his LT1 and he's probably going to be changing the cam, so it sounds like it might be a good idea to try and get his old cam off of him.
Would an LT1 cam require any mods to the heads? I would be putting new springs in anyways, but other than that? Is there any specific LT1 cam that would be most or least beneficial?
Old Jan 21, 2008 | 11:48 PM
Roton86's Avatar
Car: 86 Pontiac T/A
Axle/Gears: 3.0
Re: 305 cam help
ok i got the casting #'s
on the block: 14093638
on the heads: 14102193
Does anyone know the specs on this engine?
Old Jan 22, 2008 | 06:23 AM
86LG4Bird's Avatar
Re: 305 cam help
I'm not sure those are legitimate casting nos.
Look here for ways to identify LT1 vs L99:
http://www.impalassforum.com/vBullet...+block+casting
Old Jan 22, 2008 | 10:50 PM
Engine: LO3
Re: 305 cam help
thats an LO5. those 193 are 350 swirl port heads i know i have a set sitting at work. those i think dont quote me rated maybe 190-215? im probably wrong just a guess.
Old Jan 13, 2011 | 01:45 AM
IrocBoy707's Avatar
Car: 85 Iroc-z
Engine: 5.0 305 TPI
Re: 305 cam help
Can anyone tell me what cam this guy has. Would go good with my iroc
http://www.youtube.com/watch?v=eBL_qy7bPqE
Old Jan 13, 2011 | 05:18 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 305 cam help
eh whatever it is its too big for that motor.
Old Mar 25, 2011 | 11:32 PM
josh6219's Avatar
Re: 305 cam help
I have a 1991 rs with a stock 305 tbi what would be the biggest cam I could use also any other tips for increased power on a somewhat low budget would be greatly appreciated thanks
Old Mar 26, 2011 | 09:16 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: 305 cam help
I am also thinking about buying a cam for my 91 305 TPI. I read these work okay with stock computer.
Comp Cams Xtreme Energy 252 Camshaft (#08-407-8)
- Advertised Duration 252/258
- Lift .472/.480
Or:
Comp Cams Computer controlled (#08-300-8)
- Advertised Duration 262/264
- Lift .450/.480
Old Mar 27, 2011 | 07:25 PM
josh6219's Avatar
Re: 305 cam help
Would that give a thump to the useless because thats what I'm looking for
Old Mar 27, 2011 | 07:27 PM
josh6219's Avatar
Re: 305 cam help
Would that give a thump to the idel because that's what I'm looking for
Old Mar 28, 2011 | 05:00 PM
camaroman9191's Avatar
Re: 305 cam help
I will be using this cam in my 305 after it's rebuild ( it's getting dyno tuned after the rebuild also to tune for new injectors and higher compression) http://www.summitracing.com/parts/CCA-08-305-8/
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
