what would a stock 86 trans am with a 305tpi auto run in the 1/4?
Old Jun 30, 2001 | 08:15 PM
kernel's Avatar
just wondering because i am looking into buying on of these cars. thanks
Old Jun 30, 2001 | 09:25 PM
Guest
Guest
Posts: n/a
High 15's at 86MPH.
Old Jun 30, 2001 | 11:46 PM
whiteroc's Avatar
I owned an 86 IROC Auto four years ago. With a few mods and the engine in need of a rebuild, I managed to get it to run 15.1 in the 1/4. I never base lined it -sorry.
madmax's idea of what it should run stock sounds right to me.
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
[This message has been edited by whiteroc (edited June 30, 2001).]
Old Jul 1, 2001 | 02:17 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
look at the sig.......
my only mods are TB coolant bypass and a custom ******* intake using 3" alum flexing piping and a cone filter.
15.92 BONE STOCK with 106,000 miles
15.62 with cheap mods
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 1, 2001 | 11:39 AM
Vader's Avatar
15.29@89.1 with a few mods and the 2.77 Borg rear end on plain old Gatorbacks. I never checked it before the mods, but it's still using the "LA" cam.
Ported plenum and matched runners/base, Wells MAF, 1.6:1 Crane roller tips, AFPR @ 40 PSIG, 180°F stat and fan swithc, K&N filter (no better than a clean stock filter), on all synthetic fluids, through a full stock exhaust system, with 3/4 tank of fuel, spare, jack, all the weight left in (in street trim).
As soon as it gets to the 50,000 mile mark I'm thinking seriously about some significant head/cam flow improvements. That should be in about another two years....
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 2, 2001 | 12:15 AM
TorchTA's Avatar
Wow.
My car must be gimped all to hell then.
Back when I first got it (when i dont think it was running /quite/ up to par)
I only managed to turn like a 16.1 @ 83.
Granted it was first time at the track and all, but thats kinda sad, IMO.
It's an 86 Trans Am, TPI 305, Im told theres 3.23s or 3.27s in the back...(somethin like that)..posi too.
Hmph.
-JT
Old Jul 2, 2001 | 12:34 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Before I tore my Edelbrock carb and intake of my LG4 car, I was running 14.94@91.67mph.
I hope the TPI will at least equal that.
Well, see in a month or two when I get the car done and down to the track.
Old Jul 2, 2001 | 03:59 AM
Mista's Avatar
Car: 1986 Trans Am
TorchTA, Likely you have 2.77 gears.
What is your MPH in OD at 2000 rpm?????
about 77-79?
Then 2.77's
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 2, 2001 | 09:22 AM
85transamtpi's Avatar
My 85 t/a with the LB9 (305tpi) ran a 15.02 @ 91.5 last year. the only mods i have done are cat back exhaust and K&N. i cant wait to get out this year because i have a freshly rebuilt trans, and i think i may be able to pull high 14's (last time at track wouldnt shift into third @ full throttle).
They arent bad cars if you dont mind getting smoked by everyone with a 350.
hope that helps
Old Jul 2, 2001 | 11:38 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
85, yours is an 85 (lol, which has the l69 / hotter cam, which is why you run so much better than a stock 86 would.
My basically stock 92 LB9 in a 2.73 geared heavy *** convertible was neck and neck w/ a fully port matched SLP runner'd 87 LB9 w/ headers and 3.73s. over the weekend. Peanut cams should be one of the first things to go if you intend on doing any mods to a car w/ one.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jul 3, 2001 | 07:13 AM
Mista's Avatar
Car: 1986 Trans Am
F&&K a peanut cam! But before I go through a cam swap, I'll just drop in a 350 or 383.
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 3, 2001 | 10:19 AM
whiterocz's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
...ed
</font>
3.73s on a long runnered LB9 is IMO, dumb. maybe its ok for street racing (ie, rolling starts) but its NOT optimal for 1/4 mile at all.
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
