TPI throttle body spacers?
Old Jul 7, 2001 | 09:19 PM
lexussc94's Avatar
Does anyone use it and does it work? Also who sells them for a decent price?
Old Jul 7, 2001 | 11:48 PM
breathment's Avatar
no one seems to use them, but also i don't think the make them for the f-body TPI's, however, i have seem them for sell for the corvette TPI's, which should fit ours. im not sure where i found it, but i went to yahoo shopping, and searched for throttle body spacers, and found one for a vett for about $90.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 8, 2001 | 12:19 AM
LeftTurn1LE's Avatar
Poweraid makes them for our cars. I asked about this before and didn't get many responses. They are supposed to create a spinning air charge to increase mid-range and better atomization. I have not used one so I do not know if it works.
www.air-aid.com/pchevycar.html
Old Jul 8, 2001 | 03:31 AM
age's Avatar
age
Car: 1992 Z28 1LE
I like how they have dyno sheets for an air intake system that's pretty much anyone can do with a little bit of thought and creativity..
HOWEVER... where's the "dyno proven" power that the spacer itself actually makes? Bunch of bogus if you ask me..
Also, if creating a smooth path for airflow the key to IMPROVING airflow, then why create turbulence?
As for creating an air-fuel mixture, we're using fuel injectors at the base of the of the intake manifold, not at the TB..which means that the turbulence should be after the injector... shouldn't it?
Old Jul 8, 2001 | 08:10 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The only thing I can think a TPI throttle spacer would do is to increase the air volume of the plenum.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jul 8, 2001 | 10:25 AM
Jason M 91Z's Avatar
The last thing a TPI motor needs is for the TB to be farther away from the intake ports.
-Jason M. 1991 Camaro Z28
Old Jul 8, 2001 | 10:50 AM
whiteroc's Avatar
It would make the runners effectively longer, which would cut down even more RPM the motors are able to turn. Everyone is trying for the opposite. Don't waste your money. ...that is unless you don't mind your peak power being a 4000 RPM. ...02
89 IROC-Z 5.7L 2.77 GEARS
130,000 MILES
ALL FREE MODS
K&Ns FILTERS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
AFPR & PORTED PLENUM
Best 1/4 E.T. 14.09 @ 97.2 MPH
Best 1/8 E.T. 9.09 @ 77.4 MPH
Best 60ft. 2.03
Old Jul 8, 2001 | 11:36 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
Hey Rob, I would think that it also creates more room in your wallet.....
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
http://www.geocities.com/transam85tpi/
Old Jul 8, 2001 | 09:34 PM
Rob P's Avatar
Engine: ZZ4TPI
Trust me, I have plenty room in my wallet these days! HA
Rob P
Old Jul 8, 2001 | 09:50 PM
breathment's Avatar
YA, i think maybe if u had a carb or a different type of set up, besides ours, then it might work.
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
