How do you tell the difference? TPI
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How do you tell the difference? TPI
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
If you mean the TPI setup itself and not the motor, I don't think there is a difference. I have swapped the TPI intakes between the two several times and it works on either one.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
TPI intakes are the same for each motor
to check to see if its a Lb9 or L98, then check casting numbers on block behind the heads or in front of the passenger head, or check the cars vin code which may not always be right. A member here just the other day was asking about a cam for his 305 when he discovered it was actually a corvette L98!!
Car: '83 z/28
Axle/Gears: Stock?
Are there two specific casting numbers on the block? How would a person decipher the casting number?
Car: 89 Iroc-z
Transmission: TH400
there is a different type number on a 'pad' in front of the passenger side cylinder head and a casting number somewhere else behind the cylinder heads. they both can be used to tell what you have
code decipher on the net on sites like mortec.com or whatever it is.
Car: 92 trans am clone
Engine: LO3
or you can pull a valve cover check which heads are on the car 081=LB9 083=L98 plus itll only take a minute to do.
Engine: 383 Carb
Transmission: 4L60
Deck stamps and head casting numbers are only useful if you're certain the engine is original.
Engine: LO3
yes but using the year as a reference if it was made that year more than likely its stock if it was never on there then of course its been changed. more than likely its stock though.
Sanjay
Aug 12, 2015 03:41 PM
