305 help
Old Jan 29, 2008 | 01:06 AM
wht91z28's Avatar
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
305 help
I have a 1991 z28 with the tpi 305. I'm looking to get the car on the road this summer. I want to get some decent power out of the 305. does anyone have any good power combos that work well and any hp numbers out of a 305?
Old Jan 29, 2008 | 10:34 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 305 help
Depends on what you want to do.
The best thing you can do it headers and a nice exhaust.
Maybe a different rear end gear?
High flow runners and intake?
Port your plenum?
Cam?
maybe getting some head work done?
All depends on your pocket book.
mods I did are in my sig.
Old Jan 29, 2008 | 10:43 AM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Re: 305 help
I had a 305 with edelbrock intake, 650 carb, hooker headers, exh. and thats it. i have no idea what kind of numbers it would put down, but i can tell you that it had a good amount of power and it was really snappy. I kept up with a civic hatch w/ a turbo.
Old Jan 29, 2008 | 07:22 PM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
Re: 305 help
How much did all the mods cost you?
Old Jan 29, 2008 | 08:05 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: 305 help
Welcome to thirdgen by the way. Glad you could make it to the site!!
here we go--------------
Edelbrock high flow runners and intake $650.00 off EBay ($737.95 off summit)
Ported and polished Plenum $100 off EBay
Holley adjustable fuel pressure regulator $90.00 Advance Auto
24# LT1 injectors new $150.00
Air Foil $15.00 off EBay
104224 crane cam $230.00 Advance Auto ($285.95 off Summit)
I used my stock roller lifters
11308-1 Matching Springs $85.00 Advance auto ($99.88 off summit)
Valve seals $15.00
SUM-G6601 double roller timing gear set $37.95 off summit
SUM-G6300W Polished aluminum timing chain cover $39.95 Summit
Gasket sets maybe $50.00 (includes injectors and fuel rail)
Richmond 3.73 gear and new series 3 carrier (new seals, bearings ect.)$860.00
Ceramic coated headers and matching Ypipe $300.00 off EBay
Flow-master muffler $60.00
3" performance straight pipe $85.00
2- 18" long stainless steel tips $20.00 each
Eibach lowering springs $175.00 from a friend ($260.00 off summit)
American racing torque thrust II 17" rims and tires $1550.00 Discount tire
Custom tune $185.00 ($85.00 for the hour on the dyno and $100.00 for the tune)
Then theres accel coil, cap, rotor, plug wires, $180.00 chrome alternator.
I bought a A/C delete box got $50.00 off a friend....that will go on in the spring. I also bought the center valve cover wire looms...so that will look nice.
LOL.....so I have more in mods then what I paid for the car! Heres a pic of my car
Any other questions let me know
Old Jan 29, 2008 | 08:16 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: 305 help
hes gonna be in trouble though he has a MAP car hell have to get it tuned after any mods really to it. to get great numbers youll really need to learn to tune or find someone who can tune it.
Old Jan 29, 2008 | 08:34 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: 305 help
I did all my intake mods all at 1 time....made things easy. .....very easy!
Old Jan 30, 2008 | 07:16 PM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
Re: 305 help
thanks guys and your car looks great.
Old Jan 30, 2008 | 08:31 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: 305 help
Mod are in the signature - should be good for about a mid 14 when-ever I get myself to the track...
Old Jan 30, 2008 | 09:53 PM
Engine: LO3
Re: 305 help
atc what are the cam specs on your cam?
Old Jan 30, 2008 | 10:00 PM
atc3434's Avatar
Car: 1986 Camaro SC
Re: 305 help
Its the Summit K1102, 204/214 duration, .423/.442 lift, both @.050. Should be computer friendly with TPI, its a defintely imporvement over stock. With carb, I would go with something in the 212/218 and .460 lift range if I had built this motor.
Old Jan 31, 2008 | 09:22 AM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
Re: 305 help
Has anyone on here ever tried a 335 stoker kit?
Old Jan 31, 2008 | 09:36 AM
atc3434's Avatar
Car: 1986 Camaro SC
Re: 305 help
If you're going to pull a 305 out, make it worth your time and put a 350 back in. For the cost of a 335 you could easily build a 350 for the same cost that would out perform the 335.
Old Jan 31, 2008 | 02:06 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: 305 help
yes there a guy here named 335 something. re used a powerhouse 335 stroker kit with the tpi. and he goes i believe 13.4. not bad at all. faster than a stock l98. throw some boost on that and hello 11.s
Old Jan 31, 2008 | 10:08 PM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
Re: 305 help
has anyone seen this article theyn 372hp out of 305?
http://www.popularhotrodding.com/eng...cks/index.html
Old Jan 31, 2008 | 10:30 PM
atc3434's Avatar
Car: 1986 Camaro SC
Re: 305 help
Seen it, its a bit stretched, but doable. Change nothing but the block and you'd have 415hp on a 350.
Old Jan 31, 2008 | 10:57 PM
wht91z28's Avatar
Engine: 305cu/tpi
Transmission: auto
Re: 305 help
true i'm trying to find one i have found a couple cheap lt1 and ls1 but i don't know if it is worth the trouble.
Old Feb 1, 2008 | 12:31 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: 305 help
Why not get a cam thats compatable with the stock map ecm and some headers with a cat back exhaust.
maybe
http://www.jegs.com/webapp/wcs/store...10002_52576_-1
Thats what I would do and then just go drive it.
Old Feb 1, 2008 | 08:37 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 305 help
Don't waste a dime on any of this stuff that doesn't have long term use, get a nice exhaust and set of headers then spend the cash getting the software to datalog and burn your own proms. Next mod I'de be looking into after that would be a 350.
Old Feb 1, 2008 | 09:42 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: 305 help
my cam and everything ive done will bolt right up to a 350.
I've wasted zero money.
I already have a 350 block bored .040 over. Maybe ill start that next year. Right now I'm having fun with this 305......it runs so damn good!
Old Feb 1, 2008 | 09:50 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Re: 305 help
change nothing but that block to a 400 and youd have 45ohp and 500tq.
Old Feb 1, 2008 | 10:54 AM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
Re: 305 help
372 horsepower is pretty good..and you can still drive your car while you wait for the money for a 350. Oh and you can still blow lt1's off the road while your waiting for your "better" engine. Then you can take all of the performance stuff off of your 305 and bolt it directly, with no modification, into the 350. Seems like a great plan for the budget minded person
Old Feb 1, 2008 | 12:03 PM
atc3434's Avatar
Car: 1986 Camaro SC
Re: 305 help
Its a perfect plan, start with the easy stuff, slowly digging deeper into them motor. If money ever starts to appear in my wallet, my 305 will get a vortec swap w/ some more cam, I can justify trashing a block with 20k miles on it for 45 C.I... not on my budget anyways.
Old Mar 11, 2008 | 02:11 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: 305 help
Port your plenum?
Cam?
about how much power do you have, also is it a daily driver
Old Mar 11, 2008 | 02:31 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: 305 help
I drive it in the spring/summer/fall. I would say its a night and weekend driver.
Plus it sees a lot of car shows.
I'm not afraid to drive it places though. This year its getting a new paint job.
And the 305....It holds its own. Its got some power, and its a lot of fun to drive.
Old Mar 11, 2008 | 06:36 PM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: 305 help
cool about would you say you have your engine
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
