desktop dyno gurus need your help..
Old Jul 11, 2001 | 07:36 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i am currently building this motor a fresh 355TPI 9.4:1compression, world S/R torker heads 170cc intake runners 2.02 1.60 valves comp cam 212in 218ex .485in .495ex 112lobe sep. also adding edelbrock headers and the rest is in my sig. thanx
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old Jul 11, 2001 | 08:41 AM
R.O.B.'s Avatar
Keep in mind that Dyno2000 loves to give a lot of low-end torque, and assuming 700cfm, TPI, 355ci, Small-tube headers w/mufflers, and your cam with 108 intake centerline (by the way, which cam is this?), your readout is as follows:
RPM HP TQ
2000 147 387
2500 187 392
3000 226 396
3500 269 404
4000 307 403
4500 329 384
5000 337 354
5500 324 309
6000 293 256
6500 251 203
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jul 11, 2001 | 07:58 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
thankyou... it is a comp cam part # 08-501-8. is this close to the real world numbers or is this like within 10- 15 hp?
Old Jul 11, 2001 | 08:01 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
by the way... an MSD 6A and siameeze runners may b next the msd for sure in 3 months will this improve things??
Old Jul 11, 2001 | 08:06 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
the flow numbers for the heads r .500lift 221cfm intake ex. 166cfm at.400lift intake 205cfm ex. 156cfm
Old Jul 12, 2001 | 06:20 PM
R.O.B.'s Avatar
The flow numbers I used were:
.1 68/55
.2 128/104
.3 179/140
.4 205/156
.5 221/166
.6 225/170
From what I gather, these are CLOSE to the real world, but yet, when you through in variables like timing, port/polish intake, etc... who knows?
Old Jul 13, 2001 | 03:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've made both my engine thru Desktop Dyno 2000 and in the real world. The HP numbers DD gives were within 5-10 HP of the real world, while both times the torque numbers it shows were way lower than what I dynoed. It seems DD doesnt give enough torque to the TPI setup, because I can switch the intake from TPI to carb and the numbers barely change.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 14, 2001 | 07:28 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
hmmm.... should this get my GTA into the 13's if so what would u guess , i wanna play with LT1's LT4's. r LS1's outta reach he he :P dou think this combo will b a gas hog?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
