Air Intake
Old Feb 7, 2008 | 12:42 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Air Intake
Could I not just flip this to the other side to fit my camaro?
Old Feb 7, 2008 | 12:47 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Re: Air Intake
ya but u have to relocate the battery. SLP makes a nice one made for our cars (TPI) for about $300. u still have to relocate the battery tho. i think u can gain up to 35 hp, check fbodymotorsports.com tho
Old Feb 7, 2008 | 12:49 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: Air Intake
My battery on the driver side if I flip it be were my air box so it be empty space.
Old Feb 7, 2008 | 12:52 PM
Engine: 5.7 LSX
Re: Air Intake
HUH?!?!?
Old Feb 7, 2008 | 12:57 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: Air Intake
My battery on the driver side (90 camaro) the other side is open then I take the intake and put it together so the it’s on the other side then it should fit. That is what i am guessing.
Old Feb 7, 2008 | 01:05 PM
Engine: 5.7 LSX
Re: Air Intake
oh, well then ya it will fit. u can just turn it the other way so the airfilter is on the passenger side. do u already have that kit?
Old Feb 8, 2008 | 10:28 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: Air Intake
Nope, I'm going to be getting it. Just had to talk it out and make sure that it wound work. I’ve heard allot from people building one but nothing about modifying one so yea.
Old Feb 10, 2008 | 11:42 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Air Intake
You have a Camaro, I would use the factory twin air filter airlid stuff, along with the ram air mod that brings cold ram air up to the bottom side of the twin air filters.
Old Feb 11, 2008 | 12:33 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: Air Intake
I was just looking at the twin v8 intake but i can't find one on ebay or the junkyard.
Old Feb 11, 2008 | 04:54 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Re: Air Intake
http://cgi.ebay.com/ebaymotors/89-90...QQcmdZViewItem
Old Feb 16, 2008 | 02:10 PM
Re: Air Intake
http://cgi.ebay.com/ebaymotors/ws/eB...MEBI:IT&ih=016
Old Feb 16, 2008 | 04:45 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Re: Air Intake
I would call them and find out how far it goes from the engine to the first 90* elbow and then see how far that would go in your car to make sure it clears. If it's too long you could cut the metal pipe to length you need with a sawzall. If its just barely too short then if they could sell you a 45 to use instead of that 90 it may work. I would get every measurement you can for their intake maybe try to mock up an example made from PVC of the same diameter pipe to make sure your hood will shut properly. I doubt you'll be able to return it if you start cutting it to make it fit and find out that it just ain't gonna work. Just don't want to see you lose your money in case it won't work. If you do get it and it works, watch out for puddles, had a friend lose and engine from sucking up water through one of those things.
Old Feb 16, 2008 | 05:26 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Air Intake
FBodyMotorSports?? There are many, many, many threads full of unhappy customers of theirs in the Aftermarket Vendor Review...... I would be real leary about ordering anything from them....
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
