I pulled code 36 MAF Sensor Burnoff Failure - Need Help!!!
Old Jul 22, 2001 | 02:57 PM
maksik7's Avatar
What does this code mean? Does this mean that my MAF sensor is gone and I need to replace it or does it mean something much easier (and chepaer) solveable?
Please respond ASAP
BTW Can I use the MAF from an 88 305 TPI as a replacement?
-Max
Old Jul 22, 2001 | 03:09 PM
rondubbs's Avatar
calm down there,,
its much easier and cheaper.
all you need to do is replace the 15$ maf burnoff relay. no new maf is needed..
this relay is located on the driver side firewall, real easy to replace.
and yes , you can use that other maf as a replacement IF you needed to, which you dont.
Old Jul 22, 2001 | 03:11 PM
87tpi420's Avatar
from what i know a mass airflow burn off relay fault is most of the time caused by a relay(on the firewall next to brake booster) when you shut the car off the mass air burn relay heats up the wire in the sensor to burn off any carbon on it. if it does not burn it throws a fault code.one way to check (the way i was told) is to run car for a minute with hood open, have someone shut the care off , and put your head near the relays right up near the winshield on the drivers side, if you dont hear it click it is most likely the problem.
10-15 bucks at the dealer, simple fix if it is the problem (more than likely the problem)
http://people.ne.mediaone.net/gdm/
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Jul 22, 2001 | 04:45 PM
maksik7's Avatar
Thanks a lot for the quick responses, one more question though. Can I get this relay from a Chevy dealer cause theres no Pontiac dealers anywhere near me (my cars an 86 TA). Are the sensors the same?
-Max
Old Jul 22, 2001 | 05:39 PM
87tpi420's Avatar
yes most definately
Old Jul 22, 2001 | 08:13 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
You can get aftermarket relays as well from like an Autozone. The outer two relays use the same part number, the center relay (fuel pump) calls for a different part number, but can sub for the same number as the other relays. It's usually best to replace all three at once. If ones weak the others are also. Heres a pic Vader took showing locations.
Old Jul 22, 2001 | 10:38 PM
maksik7's Avatar
Thanks guys, but I just realized that I'm getting a parts car tomorrow and I can take the relay off of that... duh. Thanks for the picture Mike, I wasn't sure which one was teh Burnoff relay.
-Max
Old Jul 23, 2001 | 08:31 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Well you've got an 86.... is the parts car an 86? If so your relays on both cars are probably 15/16 years old, and all in the same shape. It might be good to diagnose with a part from the second car but I would put in 3 fresh relays for peace of mind.
Old Jul 23, 2001 | 11:20 AM
maksik7's Avatar
Actually its an 88 but its still the same thing. Since I'm a student and I ahve a lot of different crap to buy with my very limited income, I don't think I can throw down 50$ for 3 new relays. When those relays are toast then I'll go out and buy new ones.
-Max
Old Jan 16, 2009 | 12:16 AM
CCrockett86's Avatar
Car: 1987 Camaro Z28
Re: I pulled code 36 MAF Sensor Burnoff Failure - Need Help!!!
In the above pic, do you have the MAF power & MAF burn off relays switched? What year is that for? In my '87 Camaro I have the burn off & power relays as switched...not sure if it's my problem or just a switch in the picture...
Old Jan 16, 2009 | 12:22 AM
Stephen's Avatar
Car: 87 GTA
You replied to an EIGHT YEAR OLD POST!!! I'm sure he's not sitting by 8 years later, still trying to resolve this issue... Actually, he hasn't even been on TGO since.....
Last Activity: 06-24-2005 09:09 PM
#1...Pay attention to the dates of the posts
#2...How in the world did you even FIND a question for 8 years ago???
I'm sorry, but this is hilarious......
Old Jan 16, 2009 | 09:16 AM
Hmm, that's a good point...I'm not even sure...
That's probably why I didn't pay attention to the date, I feel like it was right in front of my face and I just responded to what threw me off.
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
chazman
Aug 22, 2015 02:01 PM
