rear main seal
Old Jul 22, 2001 | 08:25 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
rear main seal
ok i'm gonna have to replace the rear main seal.
is it a must to pull the tranny? i have a 5 spd.
what do i need to watch out for?
thanks in advance
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Hooker Competition Ceramic Coated Headers, Flowmaster, Ported Plenum
All smog equipment gone and no cat
before headers
192hp and 265tq
15.20 @ 92.5 mph 2.4 60ft
After Headers
14.480 @ 95.01mph 2.194 60ft
Old Jul 22, 2001 | 09:49 PM
Vader's Avatar
Is this really a TPI question?
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 22, 2001 | 10:31 PM
Car: 87 IROC
Transmission: 5spd
well i have a tpi and i'm sure people on this board have had this problem before.
Andrew
Old Jul 22, 2001 | 10:38 PM
Guest
Guest
Posts: n/a
Yea you have to pull the tranny to get to it.
Nothing really to watch for. Just make sure its not the oil pan leaking before you tear into the car.
Old Jul 23, 2001 | 12:04 PM
Car: 87 IROC
Transmission: 5spd
ok how do i tell the difference between the oil pan leaking and the rear main seal.
i took the cover off the bellhousing to look for oil in there and there is none on the flywheel. but on the top of the starter where the bolts go through there was oil on that. there is oil that looks to be coming out of the back of the pan.
how do i tell for sure. if its not the rear main seal i don't wanna mess with it
thanks guys
Andrew
Old Jul 23, 2001 | 03:53 PM
Guest
Guest
Posts: n/a
Clean it off real good, drive it a little, and check it out again. If its on the top of the starter, its probably coming from up higher, like the valve cover gasket.
Old Jul 23, 2001 | 10:19 PM
Car: 87 IROC
Transmission: 5spd
i changed it. it was the rear main seal and part of the oil pan gasket.
it wasn't leaking on top of the starter just kinda pooled up where the starter and engine meet.
thanks for the help though
Andrew
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
