TPI setup good flow enough for ZZ4 engine?
Old Jul 22, 2001 | 12:19 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Im planning the induction system for a ZZ4 small block with either the fast burn heads (if the vortec base comes out on time) or a set of AFR heads that are comparable to the fast burn heads....as well as an LT4 cam....im looking at roughly 430hp at 6000 rpm and 430 ft/lbs of torque at 4400 rpm (getting the numbers from scoggin dickeys website)...my car is a daily driver..and would like good mileage...but I want to run in the 12s....I would like to go with a 3.42 rear end....first....will I be able to get into the 12s N/A with these gears? Second and most important...how should I setup the TPI system? I want to stay with as much stock parts as possible since thats what I bought...first...the base...if I go vortec..i'll get the new base...if not....will a ported base from skulte handle this power...if not...should i get an edelbrock and port that one? Second..the runners...should I get stock ported...or get some SLP siamised runners? I will be porting the stock plenum....and should I go with a 52mm or 58 mm TB? Im guessing I should go with 1 3/4" headers? Any other tips welcome...thanks...oh and by the way...when everything is done..i'll be shooting a 100hp shot of NOS in her as well....but I want to be running solid 12s with out it.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Old Jul 22, 2001 | 03:36 PM
mult68's Avatar
Engine: 305 TBI
anyone?
Old Jul 22, 2001 | 05:19 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I'm not a speed parts guru, but you definatly want the ported base and the siameesed runners. You can even siameese your base as seen here --> TPI Base.
You also want to port out the plenum and go for the 58mm Throttle Body. I think they are rated at 1000 CFM.
I think you will be low 13's w/ that setup, but I don't think you will hit 12's w/o the laughing gas. Just my $.02 though.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 22, 2001 | 08:28 PM
91-ZZ4-Z28's Avatar
Go with the Edelbrock or Accel base and the siameesed runners. The throttle body is hard to say 52mm is probibly enough but I went with the 58mm just in case. If you do this with the AFR's and the HOT cam you WILL be in the 12's.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Jul 22, 2001 | 09:50 PM
mult68's Avatar
Engine: 305 TBI
Thanks a lot 91Z....your setup is pretty much exactly what I was thinking on running....what kind of gas mileage are you getting? and on what gears? Any pics? Cant wait for the new engine....will be doing the suspension and rear end in september...then hopefully installing engine during my winter break (year round school...short breaks)
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Old Jul 23, 2001 | 03:23 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I would definitely think you can run 12's with the mods you listed, as I'm almost there, and the AFR heads are much better than the L98 heads I'm running. I've also got a TPIS base and runners, and I plan on siamesing my runners soon. Definitely get the SLP 1 3/4" headers. I started with a 9-bolt 3.45 rear end and now have 3.70 gears.
What kind of pics are you looking for? I have lots of my engine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 23, 2001 | 04:55 PM
mult68's Avatar
Engine: 305 TBI
Would love some engine pics....when I do the setup Im going to try to clean up the engine bay as much as possible....if you can send them to my email address (multiple.sixtyeight@verizon.net) or post them here if theyre small enough...thanks
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Old Jul 25, 2001 | 01:50 AM
Kevin91Z's Avatar
Here's some pics of assembling my TPI intake:
http://24.1.139.249/images/112400/
And here's the completed engine, my EGR setup, and installing it into the car:
http://24.1.139.249/images/021701/
Old Jul 25, 2001 | 09:50 AM
91-ZZ4-Z28's Avatar
This is my setup.
http://www.fuelinjectedpower.com/db2...mages/pic4.jpg
Old Jul 25, 2001 | 11:27 AM
mult68's Avatar
Engine: 305 TBI
Hey 91Z...ive been meaning to ask you...your front runners look like they have two big dents in them....is that to clear something, thats how you got them, or am I just imagining it?
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Old Jul 25, 2001 | 11:36 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm running a low 13 w/ my setup w/ the stock TPI. You will defenatly be in the 12's.
P.S. - I got stock 3.23's in the rear
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass.
[This message has been edited by Free Bird (edited July 25, 2001).]
Old Jul 25, 2001 | 12:38 PM
91-ZZ4-Z28's Avatar
There not really dents, that is the way SLP casts them for access to a bolt on one side and TB hose clearance on the other side, but it does not affect air flow.
Old Jul 25, 2001 | 11:13 PM
BadSS's Avatar
Here's a picture before adding the air and fixing the cruise control.
http://albums.photopoint.com/j/View?...nce=1&res=high
Old Jul 25, 2001 | 11:53 PM
mult68's Avatar
Engine: 305 TBI
Looks good BadSS....man I cant wait to get my engine in.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Terrell351
Jun 13, 2021 01:13 PM
fonzie85
Aug 13, 2015 11:50 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
