Throttle body
Old Feb 18, 2008 | 05:57 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Throttle body
question:
the top outlet of the throttle goes to a hose for the valve cover, which I believe would be a breather, can that be blocked off??
Old Feb 18, 2008 | 08:19 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Throttle body
why?
Old Feb 18, 2008 | 12:34 PM
gscz28's Avatar
Car: 89 iroc
Re: Throttle body
because the valve covers I'm using are fitted with a filter and the hoe is tobig for the PVC grommet
Old Feb 18, 2008 | 01:45 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Throttle body
You want to keep you PCV system in place, it helps the rings seal properly.
Old Feb 18, 2008 | 02:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Throttle body
To answer your question, yes it can be plugged
I agree with them, the PCV system is beneficial
If the grommet is the wrong size then get a bigger one or a different size PCV valve
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
