What Voltage Should I Get at CTS Connector?
Old Jul 28, 2001 | 07:20 AM
GTA88's Avatar
I want to make sure I am getting the right voltage (or ANY voltage) at the wiring going to the CTS. Can I just turn the key on, engine off, unplug the CTS connector, and put my voltmeter probes into the connector terminals? Does it matter which probe goes where ? Could I damage anything if I hook up the probes backwards ( pos / neg)?
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jul 28, 2001 | 09:12 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The CTS actually gives resistance (or ohms) across the two terminals. Very high indicates a very cold reading and low resistance indicates a hot reading.
There is a corresponding chart of resistance to temperature readings available somewhere on this site.
Old Jul 28, 2001 | 09:32 AM
GTA88's Avatar
I just want to see if any voltage is getting TO the cts. I want to test the connector voltage going INTO the cts.
thanks
Old Jul 28, 2001 | 05:32 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its either 12V or 5V, I don't remember.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 28, 2001 | 11:06 PM
airdeano's Avatar
i believe its a 5v reference yellow, reading the
resistance back on the brown wire.
my si2000 is down.
if you arent getting any voltage, ohm the
wires from the connector to computer.
and if ok... get a computer.
i should be able to get the pin outs for
the CTS to computer connector. ill have that
monday...
airdeano
Old Jul 29, 2001 | 09:27 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Are you accessing SI2000 from your harddrive (CD Version) or are you getting it off the "net"? (its available on the internet too). Problem is, SI2000 doesn't show wiring diagrams older than 1998, so how are you going to look there?
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old Jul 29, 2001 | 10:56 PM
airdeano's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GMTech:
</font>
then breakout the service manual...
si2000 off the CD..
airdeano
Old Aug 2, 2001 | 06:50 PM
aquila's Avatar
the yellow wire should read 5.0v +or- .1 to ground and across the terminal to the brown wire. please do not do not test the computer for resistance, they don't like that. if you need to test the wires to the computer disconect the computer first and test the wires separate.
Old Aug 3, 2001 | 02:23 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You can test computer connections for voltage no problem. Just make sure to use a digital VOM.
KCG
Jun 24, 2020 04:33 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
BumpaD82
Feb 26, 2016 02:57 PM
91 SrS
Oct 7, 2015 04:32 PM
RS Reaper
Sep 27, 2015 07:04 PM
