Engine wont stay running
Old Feb 23, 2008 | 09:39 PM
weinz90's Avatar
Car: 87 IROC, 96 Suburban
Engine: 5.0 TPI, Vortec 5.7
Transmission: T5, Built TCI 4L60E
Axle/Gears: 3.45 posi, 3.73 eaton locker
i got the motor back in and have all them vacuum lines hooked up. it starts up and runs for 2 seconds then dies. i have a question about the electrical connectors, i have all the female connectors hooked to male connectors but there are alot of male connectors left over (3 or 4) and its been a while since i took it apart and cant remember if it was like that before. anyone else have an lb9 5 speed car with extra connectors just hangin out. thanks.
Old Feb 23, 2008 | 10:04 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: Engine wont stay running
weinz90,
Check your engine grounds. You have two sets of wires on the back side of both heads. I believe its two but I think the driver's side might have three. Make sure the bolt is tight. If I recall properly its a 9/16ths.
Rabi C.
Old Feb 23, 2008 | 11:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You might want to post pics of the loose connections...your description of what isn't connect really lacks substance.
Old Feb 24, 2008 | 09:17 AM
weinz90's Avatar
thanks rabi, ill try that. ill take some pictures today.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Sherpajames
Aug 7, 2015 06:56 PM
