injector cleaning?
Old Aug 6, 2001 | 10:47 PM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
injector cleaning?
Who does it the cheapest and most reliable? Thanks!
Wally
Old Aug 6, 2001 | 11:08 PM
breathment's Avatar
you can goto NAPA and pic up a bottle of injector cleaner that hooks up in place of ur regular fuel line, then the engine runs off the bottle cleaning the injectors until the bottle runs out, supposed to be pretty good and cost like $15-20 for the kit, and then u can just buy replacement cans later. its about the same price as going to have it done somewhere and is probably the same technic used.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 7, 2001 | 08:38 AM
gravitar's Avatar
I've heard good things about this place..
http://www.cruzinperformance.com/
I would imagine that having the injectors ultrasonically cleaned off the car would do a better job than a can of solvent that hooks up to the fuel rail, but I don't know for sure.
Old Aug 7, 2001 | 04:05 PM
camaro89RS's Avatar
I just got my injectors back from cruzinperformance and i think that it is worth the $10 per injector.
Jason
Old Aug 10, 2001 | 10:27 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'm trying to take my injectors out to send them to them but I am stuck. I got the plenum off and the bolts to the fuel rail out, but I can't get it to come off. The book says to turn the lock tabs counter-clockwise to release them. I have done that to the driver's side injectors but I can't get the other side to do it. The tabs just won't budge. They are really stuck. Can I use some carb cleaner to loosen them up? After I get those tabs turned, how does the whole thing come out? Does it come out as one unit or do I have to take the crossover tubes off also? And do the injectors stay on the engine or do they come with the rails? Any help is greatly appreciated.
'91 GTA
350 TPI
700R4 from Pro-built
T-Tops.
Just a few mods, if you want to find out just line up next to me at a stoplight!
Wife:2000 Grand Prix GTP
Old Aug 10, 2001 | 12:33 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Unbolt the fuel rail hold down on the intake, unscrew the fuel lines, and pry the whole fuel rail (injectors and all) off the manifold. Once you have the assembly off, you can then manipulate the locking rings that hold the injectors to the fuel rails
and pull the injectors out. You will be replacing all the O rings anyway, so I wouldn't sweat messing them up.
My 89 Formula
13.98 @92 mph 2.06 60 ft
1989 Firebird Formula, WS6 Package, ZZ4 Crate engine.
MSD 8.5mm Super wires, SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust,
Random Tech 3" hi flow cat, K&N filter, 700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band,
2200 rpm stall converter, Borg Warner 9 bolt 327 rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's,
Spohn subframe connectors, custom chip, Walbro hi-flo fuel pump.
Accel stuff: 24 pound injectors, Superram intake, Large tube runners, billet distributor, supercoil.
Old Aug 10, 2001 | 02:02 PM
Thanks. I was worried about screwing up the injectors themselves or the fuel rails.
'91 GTA
350 TPI
T-Tops.
Old Aug 10, 2001 | 02:11 PM
Guest
Guest
Posts: n/a
Dont forget about the bolt in the front of the intake that holds down the metal lines that run off the rails.
Old Aug 10, 2001 | 02:28 PM
I don't remember any bolts on the front that are holding down the fuel rails other than the main four bolts. I'll look though.
Old Aug 10, 2001 | 02:53 PM
camaroguy99's Avatar
there is a bolt on the font of the intake that holds down the fuel lines running to the chasis lines. it's right on front ofthe intake base, you can't miss it.
Old Aug 10, 2001 | 03:11 PM
OK, now I know what bolt you are talking about. Its the one that holds down the bracket for the incoming fuel lines. Yes, I unbolted that one. It was a ***** with the lines in the way. I was just trying to prevent damage to the fuel rails or the injectors when I pulled them off. I will try agiain with more force today when I get off work.
Old Aug 10, 2001 | 11:30 PM
I was able to get the injectors out with a little more muscle. I was afraid to mess them up but they popped out after I removed the crossover tubes. BUt the EGR valve is in the way for the fuel rails to come out now. Damn, what next?
Old Aug 11, 2001 | 08:52 AM
Vader's Avatar
BS,
You must be right about here in your disassembly:
You may have to remove a fuel line between the rails to allow it to clear the EGR valve, or remove the EGR itself. This is a very good excuse to clean the EGR ports and valve base of all the carbon deposits. Don't forget to reassemble everything with anti-seize compound.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 13, 2001 | 11:03 AM
<font face="Verdana, Arial" size="2">Originally posted by Vader:
BS,
</font>
That's exactly where I'm at. I took the thermostat housing off to get it out of the way. (Is it bad to have coolant leak into the injector holes?) J/k. I got them out over the weekend. The injectors are on there way to cruzinperformance right now.
'91 GTA
350 TPI
T-Tops.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
