305 to 350 tpi
Old Nov 1, 2000 | 04:45 PM
bman's Avatar
305 to 350 tpi
I have a 305 tpi motor and wanted to put the fuel injection on a 350. Was just wondering what the dif is between the tpi off a 305 and 350.
Old Nov 1, 2000 | 05:04 PM
cobrakiller1989's Avatar
im pretty sure its just the injectors and PROM
Old Nov 1, 2000 | 08:49 PM
IrocManiac's Avatar
Just the injectors and a chip. Get 22lb injectors for the 350 and a new chip and you should be good to go.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Nov 6, 2000 | 08:30 PM
Jason M 91Z's Avatar
Also the knock sensor is different.
-Jason M. 1991 Camaro Z28
"Its Blue."
Old Nov 7, 2000 | 09:55 PM
FormulaGod's Avatar
I did this swap in May. Everything bolted up perfectly. I have a fully modded 355 tpi and havent even taken out the 305 chip yet!! I will soon though..
"Ever notice how imports sound like weedwackers"
Old Aug 13, 2001 | 10:18 PM
nitroscj's Avatar
[QUOTE]Originally posted by FormulaGod:
[B]I did this swap in May. Everything bolted up perfectly. I have a fully modded 355 tpi and havent even taken out the 305 chip yet!! I will soon though..
Hey formula god, did you ever swap chips? Was there a noticable differance?
Old Aug 13, 2001 | 11:23 PM
chiefz28's Avatar
FWIW not sure what year your cars are didn't see a SIG.But it's to my understanding that 90-92 SD both have 22#injectors.pre 90 were the ones with the 19#.so if your car is a 90 or newer your already set with 22.Just don't want to see spend your money on something you already have.Instead you can use the money to buy some other fast part
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
