What parts come with new Throttle Bodies?
Old Aug 18, 2001 | 05:39 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I am going to be buying a new 58MM throttle body. I bought a used TPI system....and noticed that one of the screws that screws the bottom half of the TB (where the IAC is screwed into) to the actual TB was broken off...so I cant take it off. Not really a problem since i'll be ditching the TPI system for a superram. However, when I buy the new TB...will it come with the bottom part as well? All the pics ive seen seem to be missing this part. If they do...good. If not, where can I get a new one from? I dont want to bother with drilling and tapping new threads.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
Old Aug 18, 2001 | 07:51 PM
rondubbs's Avatar
it dosent come with the bottom part.
you can get one from a junk yard or GM parts store.
Old Aug 18, 2001 | 09:46 PM
mult68's Avatar
Engine: 305 TBI
Do you happen to have a part number for it? Im looking for it..but it seems to not have a part number
Old Aug 19, 2001 | 01:13 PM
rondubbs's Avatar
i believe you are talking about part 61, part 70 is the IAC and you can reuse it. 61 has to be transfered from the old tb to the new.
Old Aug 19, 2001 | 02:22 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
not to stop u .. but if u are planning on putting a 58mm on a tpi 305.. u are going to come into alot of issues. thats just WAY to much air for the engine... i have a 406 that i decided to put a 58mm TB onto because later it will have a S/C... but i could have gone with a 52/54mm T.B. so id seriously think about just getting a 52mm..btu hey its your $$.. im just trying to give u a heads up.
[This message has been edited by aziroc (edited August 19, 2001).]
Old Aug 19, 2001 | 03:45 PM
mult68's Avatar
Engine: 305 TBI
Well its going to be on a 383 Superram......and yes Ive been told to go with 52mm....and ive been told to go with 58mm....probably a debate that will keep going....i think i'll just go ahead and go with a 58 since the superrams tb holes are 58.
And 54mm would probably be the best to go with...but the only place ive seen that makes them is AS&M...and its da*n expensive.
[This message has been edited by mult68 (edited August 19, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
