Question about Spark Plugs
Old Mar 13, 2008 | 07:56 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
I was just wondering what are some of you guyz using as a plug on a pretty much stock 350 TPI except free-mods? My mechanic told me to ditch the Bosch Platinum 2's I just put on it and grab some AC Delco's, what do you guys think?
Old Mar 13, 2008 | 08:31 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: Question about Spark Plugs
Delco replacements arent bad for a basically stock L98, thats all i put in on my last tune up. But the with the bosch platnums you arent gonna notice a performance difference really, although the longevity of the plug is increased as it is made of higher quality materials. Now a more highly modded motor or the use of power adder will need a more high quality lower heat range plug. But, with your set up Ac delcos will get it done for you
Old Mar 13, 2008 | 08:32 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
I have a friend that had a '91RS 3.1 a few years back. He had Bosch + 4's in it. Someone told him that they were crap and that he needed to change them. So he changed to a conventional spark plug and immediately noticed reduced performance. He just wished he hadn't thrown away the Bosch plugs.
Old Mar 13, 2008 | 08:58 PM
FormulaL98's Avatar
no doubt plugs can affect peformance. I just havent noticed any major difference in any of the motors ive built or maintained, often if the motor is close to stock (heads cam intake) there are restrictions other than the plugs so a expensive plug is not really needed. really either way you go on the plugs will work well, more or less depends on if u wanna spend a little more money per plug i suppose.
Old Mar 13, 2008 | 09:00 PM
Car: '87 Iroc-Z
okay my problem is this, I originally had bosch platinum 4's when I bought my car, Car ran great as hell. I changed them to autolite's which reduced performance, I recently did a spark plug, wires, car and rotor change using accel parts and bosch platinum 2 spark plug which resulted in a misfire. My engine guy said that the problem lies in the bosch 2's, he says their crap and to go to Delco spark plugs. Whew... Now do you suggest this or what?
Old Mar 13, 2008 | 09:02 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
The AC Delco's are perfectly fine. And for the performance thing..I highly doubt anyone will feel a difference from spark plugs.
Your problem is most likely not the plugs, it's all the accel stuff. I've heard bad things about accel parts in general on this site.
Old Mar 13, 2008 | 09:04 PM
Car: '87 Iroc-Z
okay so....are the bosch 2's crap and could possibly be causing my car to misfire?
Old Mar 13, 2008 | 09:08 PM
irocz28boy's Avatar
Car: 2000 Z28
I don't think the bosch 2's are your problem, but I would still go with the AC's. There's no reason to get a higher grade plug when you don't have a high performing engine.
Old Mar 13, 2008 | 09:24 PM
Car: '87 Iroc-Z
So, I did a lil research real quick and i've came to the conclusion that I am going to and should replace the accel cap,rotor, and spark plug wires.
More than likely I will replace with Hypertech car,rotor,coil and use MSD StreetFire Wires. sound like a good choice?
Old Mar 14, 2008 | 12:13 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Throw in some AC plugs, MSD cap, rotor, coil, wires, and call it a day. If you have a autozone nearby their Conrad cap and rotor with the brass terminals is very good as well.
Old Mar 14, 2008 | 03:34 PM
FormulaL98's Avatar
Thats exactly the set-up on my car, cant complain one bit about it.
Old Mar 14, 2008 | 07:20 PM
ljnowell's Avatar
Something that should be said. Im sure most of the people here know this, though some may not. When the parts store guys try to push the gimmick plugs (+4s etc) they have the little picture with the spark "flower" of flame coming of the 4 contacts. More spark, thats the sales pitch. This is bogus. Electricity will follow the path of least resistance. One path only. It will not spark to both or four at once. It may alternate, as heat changes and resistance may change, rapidly. But it will not make 2 seperate sparks as show in pictures and related to the customer. In most cases it will in fact make a smaller spark, that will not be any more intense.
Old Mar 14, 2008 | 11:25 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Since we are on the subject of plugs I want to mention that last year I changed the plugs on my 2000 blazer with Autolite platinums. It barely ran after that. Turns out the #6 plug was non-functional out of the package. Autolite=crap imo.
Old Mar 15, 2008 | 08:46 AM
92fireformula's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tpi
What are your opinions on ngk spark plugs?
Old Mar 15, 2008 | 08:59 AM
grizzlyta44's Avatar
Car: 1986 Trans AM
Engine: 305ci tpi
Axle/Gears: 2.77 Borg Warner
Working in numerous parts stores over the years I can tell you the only time your really going to see any difference with the bosch +4 or +2 is if you have some type of blowby. someone mentioned earlier the path of least resistance, at this is where it holds true. It allows the spark to travel down the least coated path. If you have a good running motor Delco's work great!...as per NGK put them in your dirt bike, not your car.
Old Mar 15, 2008 | 12:33 PM
Abubaca's Avatar
I use the AC Delcos. I've never put anything else in. Car runs great.
Old Mar 15, 2008 | 02:33 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
NGK are a great plug
Old Mar 16, 2008 | 10:39 PM
Car: '87 Iroc-Z
yeah,switchin back you the delcos but using hypertech cap rotor coil and msd streetfire wires
Old Mar 17, 2008 | 02:01 PM
wolfspirit187's Avatar
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
Im running the bosh plat plugs not the 4 or 2 the single ones what i noticed is it seems to run cooler then the ac delco ones i tried it also on my bone stock oneengine and felt no diffrence so if you have the free mods and opend air andless resctrive exhaust you can fell a diffrence in throttle responce, and and ya they last longer imop but this jsut me
Old Mar 20, 2008 | 03:37 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
I put brand new bosch +2's on my 350 tpi and the engine would shudder in overdrive. After changing numerous things, I eventually went back to regular Ac Delco's and the problem was fixed. Car has run strong ever since. Plus, you dont feel bad changing your plugs often because they are 4-times cheaper than Platinum plugs. Just my experience.
Old Mar 21, 2008 | 08:51 AM
Car: '87 Iroc-Z
thanks bros i have the same problem with my bosch +2 switchin back though
Old Mar 21, 2008 | 10:01 AM
FormulaL98's Avatar
let us all know how your car runs after switching back. do a burnout or somethin and show us that too lol.
Old Mar 21, 2008 | 03:02 PM
Car: '87 Iroc-Z
rodger that lol
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
