Air Box Air Deflectors
Old Aug 26, 2001 | 01:28 AM
I Cant Think of Anything's Avatar
I just bought an 89 Iroc I have been doing a lot of maintenance on it and when I took off the plastic intake and filters I found these flaps that you can unbolt that redirect the air entering the air box. I took them off to allow more air to flow but what is the point of these flaps? Do they do any good?
1989 Iroc-Z Blue T-Tops
Modes:
Headers, B&M tranny, K&N's
Old Aug 26, 2001 | 03:51 AM
rezinn's Avatar
They prevent water and crap from getting on your filter, they aren't really necessary.
Old Aug 26, 2001 | 11:27 AM
Fastcamaro87's Avatar
they also make the car quieter, for example, if u put a k&n on it or gut the airbox completely, you will notice it sounds like it is sucking air.
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,MAF sensor screens removed, gutted air box, ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 20w50, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Aug 27, 2001 | 08:35 AM
IROCKER's Avatar
As fastcamaro87 said, they are basic used as silencers. Not so much for water and stuff...that's what that plastic piece/baffle is for underneath the airbox.
Just take the fins out, and toss them.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
3rd Place Stock Class at annual 2001 JCO Bash
Web: http://www.angelfire.com/on3/whitelightening
Old Aug 28, 2001 | 12:55 AM
Iroc n roll's Avatar
Absolutely worthless pieces of plasitc. Hacksaw off the bottom of the airboxes (Right above the vents) and slap some reuseable filters (K&N or Holley) in there so you can clean them when they get dirty. Andris Skulte has a ram air design that you can use to build your own ram air for your car. Its in the Tech Section I believe, or find it on his site www.skulte.com.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
