running so rich it stalls.
Old Mar 24, 2008 | 07:42 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I am having this problem and i cant seem to figure it out. I am runnning amazingly rich. I cant keep it runnning unless my foot is on the pedal some. I did get it to idle great, but then i checked my timing and it was up to 50*. This made me realize I had to be dumping fuel in the motor because it took 50* to burn off the fuel right?
As of right now i lost my old maf and borrowed a buddies. It looks in bad condition and I was wonderig if the maf is bad or the maf relay is bad, could it cause my injectors to be spewing fuel into the intake? I checked my plugs and theyre pig black.
My injectors are brand new, but i di cut the injector wires because i was starting the megasquirt setup, but i decided to stay stock for now. When i rewired the injector wires i didnt know which wire went to the exact one, which shouldnt matter as long as they are on the right bank
What are some signs of a bad
Old Mar 25, 2008 | 10:39 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: running so rich it stalls.
Two things:
24# injectors will run rich. Did you reset injector constant in the eprom?
And all eight injectors fire (spray) at every 4th distributor pulse (double fire).
There are 2 fuses, 2 banks (4 injectors each), 8 (12 volt) power wires, 8 ground wires, and one "short to ground, to fire" ECM driver.
Old Mar 25, 2008 | 11:13 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Alright I understand the 24# injectors, but I have been running them like that for a while. I was curious as long as I wired the 4 injectors on one bank to the wires on the one side in no specific order it was okay.
Old Mar 25, 2008 | 03:22 PM
pa_richardson's Avatar
I Have the exact same problem and can not work it out.
I have changed all sorts with no luck at all, Mine starts then runs really rich you can smell it also smokes with it..I pulled the whole thing apart today even unloomed the whole loom for problems there..If you figure it out please let me know if i do first i will you..Checkout chevythunder.com for clues or ecm wiring fo your injectors.
Good luck
Old Mar 26, 2008 | 10:52 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Do a search on "wrong ecm" (Tech boards TPI). It is a resent post and has the wiring diagram listed.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
