I have the Firebird style air intake. Does anyone have the own home made cold air???
Old Sep 7, 2001 | 07:49 PM
JucinGTA's Avatar
A guy told me he had to identical built cars, one was a IROC and the other A Trans am, they both had the differnt intake setup, he said the IROC was alwyas 6/10s faster because of the way the firebirds shady, and small intake route to the passenger side. Does anyone have pics or there own way they made the intake bigger??????? PLEASE HELP!!!!
Old Sep 7, 2001 | 08:16 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Hi,
Go to "My Ram Air" section on Ron's page and you will see the way he did it:
Ron's 91 Formula Page
Hope this helps.
(Edited to fix link)
1992 Pontiac Firebird Formula (original 305 TBI) The project has begun:
just purchased 1986 Corvette 350 TPI, Summit SLP 1 3/4" Headers, Dual Catco Cats, Flowmaster American Thunder 3" Exhaust, Dual fan setup, OEM Posi, GM 3.42 gears and JEGS Ultimate Support Cover for 7.5 rear.
1997 Chevrolet Camaro SS # 379 (1 of 371 Black, T-Top, 6-speed)
1973 Chevrolet Camaro RS/Z28
1969 Chevrolet Camaro SS 350
RIP Dale Earnhardt.
[This message has been edited by 92 Formula (edited September 07, 2001).]
Old Sep 7, 2001 | 09:02 PM
JucinGTA's Avatar
Hey thanks for that it looks really good, but im talkin about a cold air induction, the that comes from the T/B to the top of the air filter canister.
Old Sep 7, 2001 | 09:35 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
http://edit.photos.yahoo.com/bc/amah...?.dir=/formula
If this works it is a pic of a camero air box on my 88 formula. I plan on mounting some scoops under my bumper wich will force the air up in to the box.
Old Sep 8, 2001 | 02:25 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've done the cold air thing and have it posted at
http://www.geocities.com/jonathan_badgett/
the pictures are VERY large and I don't know if anyone can visit it right now since Geocities just sent me an email saying that I've exceeded my monthly bandwith of 3GB. Hope it works for you.
Old Sep 8, 2001 | 09:40 AM
JucinGTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 3.1EyeCandy:
</font>
Hey where did you gt that pipe at?
Old Sep 8, 2001 | 02:46 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
<font face="Verdana, Arial" size="2">Originally posted by 88 350 tpi formula:
</font>
Thats pretty cool, how hard was it to do? Notice any difference in power?
Jess
Old Sep 8, 2001 | 04:43 PM
Team FTS's Avatar
I just removed the air filter housing and bolted my K&N in with that long bolt that used to hold the housing and connected the plastic tube that comes from the throttle body
Old Sep 8, 2001 | 05:50 PM
JucinGTA's Avatar
What Im tryin to get at is, the size of the tube itself, its too small in diameter, I want to increase the size!!!
Old Sep 8, 2001 | 08:11 PM
Car: 1987 GTA
Transmission: 4L60e
I got the pipe from an exhaust shop. It's the same one used on diesel exhaust. Just welded to gether with a straight piece and painted. It's 3 1/2 inches in diameter.
Old Sep 9, 2001 | 10:39 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
this isn't mine but it's what i'm going to do
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
[This message has been edited by 91banditt2 (edited September 09, 2001).]
Old Sep 9, 2001 | 11:06 AM
Engine: ls1, LB9
The box mounting itself was not that hard. you have to cut the firebird one I was unable to just snage a a camero one there hood latch and spring are a little differant than ours.(If you can get a pic of a camero you would see what I mean) the hard part and the part that really makes it not worth doing is you need to modify the hood and doing this takes a long time because you need to bend in the spots on the hood just above the box without making marks on the out side of the hood. I ended up cutting the sides by the latch and denting them in and finally using fiberglass so it wouldn't look like I just hacked it all up. I really did not notice one bit of hp. but, I guess the camero only has 5hp more. I will have to see what happens when I install some scoops under it. It just shows that the box can fit.
Old Aug 1, 2008 | 01:13 AM
1BADKIDD's Avatar
Re: I have the Firebird style air intake. Does anyone have the own home made cold air
https://www.thirdgen.org/forums/body...-92-trans.html
trans am hood vent idea
Old Aug 1, 2008 | 10:47 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You need to do a search. There have been dozens posted. Do a search with "cold air intake". Pick the one you like.
Old Jan 4, 2021 | 05:16 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
I have an original clean SLP kit with the airbox, ducting with airfoils, clamps and nice k and n filter. also special maf bracket. if you want pics pm me.
Old Jan 8, 2021 | 08:35 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
i commented on this in response to the initial post but holy **** this is an old thread you bumped
Anton28
Alternative Port EFI Intakes
Jul 25, 2020 11:13 AM
pontiacpower350
Jan 10, 2004 09:50 PM
white88formula
Oct 29, 2003 11:54 AM
aaron7
Mar 27, 2003 09:30 AM
Mathius
Oct 26, 2002 11:33 AM
